Resolvin the flooding problem!
Old Feb 28, 2002 | 03:01 AM
LLman's Avatar
Lucky owner
Wink Resolvin the flooding problem!
Hi!
I discovered that when engine is cold and you wanna turn it off without flooding it. Best way is to rev it up to 4k and then turn off the ignition while holding a throttle.
And no trouble starting it next morning.
LLman
Old Feb 28, 2002 | 04:19 AM
The Ace's Avatar
Greek Power
You must be talking about NA, because if you do that in a Turbo you will get 2, maybe 3 chances to do that. After that, its bye-bye turbo
Old Feb 28, 2002 | 04:34 AM
NZConvertible's Avatar
I'm a boost creep...
Hell yeah, you'll fry those turbo bearings in no time! Don't do it ever!
Old Feb 28, 2002 | 05:06 AM
LLman's Avatar
Lucky owner
Yes I have N/A & you are right about that turbo stuff.
I just forgot to write it.
sry
LLman
Old Feb 28, 2002 | 10:55 AM
Mark S's Avatar
I remember reading CYMFC3S said this is what he does to prevent flooding. I assume he meant on turbos as well?
Old Feb 28, 2002 | 01:14 PM
RETed's Avatar
I dunno about doing this...
The reason it prevents flooding is that the increased heat from the high revs vaporizes any fuel that's still in there.&nbsp At the same time, it also vaporizes any oil that's in there that helps lubricate the engine normally.&nbsp This might not do anything short term, but I'd like to see if it's safe to do this over a long term stretch.
Really folks, a fuel pump cut-out switch is very easy to install and works everytime.
-Ted
Old Feb 28, 2002 | 01:21 PM
Matt22's Avatar
Fear The RE
Hey Ted
where can i find a install guide for
the fuel pump cut off switch. sounds
like something i might want to do..
Thanks Matt22
Old Feb 28, 2002 | 01:22 PM
RETed's Avatar
Do a search?
I've been messing with the idea of doing a write-up, but I'm too lazy at the moment.
Maybe I should get off my butt and go put it up!
-Ted
Old Feb 28, 2002 | 01:24 PM
J-Rat's Avatar
Alcohol Fueled!
I posted some pics not too long ago on a different thread...Hold on, I will find it.
https://www.rx7club.com/forum/showth...t=fuel+cut+off
Read down the page..There are pics I took, and everything.
Rat
Old Feb 28, 2002 | 02:09 PM
NjFC3S's Avatar
-Ted
When I bought my FC it already came w/ a fuel cut-off switch and that's good 'coz I have no idea how to install such thing. Lucky me, huh?..
Old Feb 28, 2002 | 04:07 PM
J-Rat's Avatar
Alcohol Fueled!
Dude..I am here to tell ya...Fuel cutoff switches are EASY, and REALLY CONVIENIENT!! If I hadnt put one in, I cant imagine how many times I would have been stranded...
Old Feb 28, 2002 | 05:26 PM
J-Rat's Avatar
Alcohol Fueled!
I have an N/A so I am not too concerned...
Old Feb 28, 2002 | 06:01 PM
7UP YERS's Avatar
put the fuel cut=off switch in,it worked wonders for my motor man
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
