Is there a differece between a clutch for a convertible and non-convertible fc
Old Sep 17, 2006 | 03:36 PM
fleen7's Avatar
FLEEN7
Exclamation Is there a differece between a clutch for a convertible and non-convertible fc
Is there a difference between clutches for a convertible and non convertible FC?
Old Sep 17, 2006 | 04:13 PM
13b4me's Avatar
No
Old Sep 17, 2006 | 05:19 PM
Icemark's Avatar
Yes. They have different P/N for the clutches and have different transmissions.
Old Sep 17, 2006 | 05:46 PM
jackhild59's Avatar
Rotary $ > AMG $
Mark-
Does this apply to the S4 only or does it also apply to S5?
Thanks
Jack
Old Sep 17, 2006 | 06:06 PM
deadRX7Conv's Avatar
Opinions are like........
I want to know that also.
What is different between the S5 NA and S5 vert manual tranny?
What is different between the S4 NA and S4 vert manual tranny?
I've noticed some PN differences, like motor or tranny mounts, driveshaft(or was it the driveshaft dampener), clutch kits..........
I always wondered if the 'vert pieces were tailored to smooth out the driving experience, and to help mask drivetrain induced chassis wiggle. But, from what I've noticed, the trannies were the same.
Old Sep 17, 2006 | 06:43 PM
13b4me's Avatar
They are still interchangable...
Old Sep 17, 2006 | 06:59 PM
Icemark's Avatar
The convertibles used the M50N tranny, while the non turbo coupes used versions of the M582 (depending on what year).
I don't know what is actually different as far as the clutch, but I suspect that you had a higher clamping force (due to the increased weight of the car) and slightly oversized clutch plate (probably simular to how the S4 Turbo clutch is a 240mm, while the S5 is a 235mm- yet the two fit just fine to the same flywheel and housings and are completely interchangeable in the aftermarket world).
As far as motor mounts, yes the vert motor mounts were stonger to make the engine more of a structural member.
Old Sep 17, 2006 | 07:01 PM
13b4me's Avatar
Good info Mark!
Old Sep 17, 2006 | 08:40 PM
fleen7's Avatar
FLEEN7
thanks
Old Nov 7, 2008 | 09:06 PM
Brink-of-Time's Avatar
No PSTNS Vert
Huh, I didn't know that. I just put a coupe trans into my vert since my old trans had two blown syncros.
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
