Malfunctioning Oil Pressure Gauge!!!!
Old Feb 27, 2002 | 09:47 PM
kim307's Avatar
I have a 89 GTU and the oil pressure gauge just goes all the way to the top as soon as I start the car. Anyone have this problem or heard of it?
Jay Kim
Old Feb 27, 2002 | 09:52 PM
damn hippies
i had that problem with my thremo when i broke the radiator...haha boy that was a bad night, id say the gauge is bad try a new one
Old Feb 27, 2002 | 10:06 PM
Juan's Avatar
Im a tall midget.
Try cleaning the connection from the oil pressure sender thing. Its right below the oil filler tube (round thing with a white connection on it). Alot of oil/dirt get in between the sender and the wire. Slide the plug off and clean it. If that doesnt work just buy a new gauge from the junk yard.
Old Feb 28, 2002 | 03:39 AM
The problem is almost certainly not the gauge itself. It is more likely to be the sending unit (mounted just below the oil filter) or a wiring problem between the sending u nit and the gauge.
Old Feb 28, 2002 | 12:10 PM
HAILERS's Avatar
HAILERS
Something missing here. Does the oil pressure needle come back down when warmed up? If you just turn the key to on and not start the car, does the needle rise????
Old Feb 28, 2002 | 12:12 PM
MaxRX7's Avatar
hambre y sueño
mmmkay
Old Feb 28, 2002 | 12:18 PM
kim307's Avatar
If I put the key into the "ON" position, the needle starts rising and yes it does come back down after I turn the key off. What's the significance of this???
Jay Kim
Old Feb 28, 2002 | 12:56 PM
BlackRx7's Avatar
Daily Domestic Killer
well You got it better that me, my needle just sits at the bottom and never moves, replace the oil pressure sender unit with one from the junkyard and still nothing.
I just check my Oil level like everyother day
Old Feb 28, 2002 | 01:00 PM
RETed's Avatar
Be very care of problems with oil pressure readings, especially if they are low.&nbsp Verify oil pressure with a known, good mechanical oil pressure gauge FIRST!&nbsp If it reads normal oil pressure (30psi at idle, 60-70psi at 3kRPM+), then it's the sensor or wiring.
If you confirm you have low oil pressure, it's most likely the o-ring in the front cover.&nbsp YOU NEED TO TAKE CARE OF ANY LOW OIL PRESSURE PROBLEMS AS THIS WILL KILL YOUR OIL SEALS!&nbsp At the very least those oil seals will disintegrate, and worse case you'll kill all the bearings in the engine.
-Ted
Old Feb 28, 2002 | 05:23 PM
HAILERS's Avatar
HAILERS
If you just turn the key to the on position, and do not start the engine, and the needle rises above zero, then its the probably the sending unit but not for sure. Take the connector off the sending unit and keep it from making a ground and then turn the key to on without starrting the engine. Did the needle move above zero??If it did its possible you have a short in the wiring. Its still unclear if after starting the engine, whether or not the needle returns to a respectful reading after the engine is warmed up. If you want to check the gauge for reading correct, take a 142ohm resistor and connect it b/t the wire that goes to the sending unit and a good ground. After a few minutes the gauge should read 60psi with the key on. That check is in the factory manual thats free on the internet. For true accuracy, buy a aftermarket at the store such as SunPro(cheap) and screw it into where the sending unit goes.
Old Feb 28, 2002 | 05:55 PM
DC350's Avatar
Rotor Head
i heard that RX7.com says the gauge is a joke! and you should get an new one
Old Feb 28, 2002 | 06:21 PM
Poindexter10thae's Avatar
AKA Poindexter
I agree the stock gauge is a joke I just didnt like the increments of the gauge (going from 30 to 60 to 110 annoyed me). I just got an aftermarkted electric gauge(autometer).
Old Feb 28, 2002 | 06:29 PM
rx-7fc's Avatar
it is the gauge because mine did the same thing and i put a new in and it worked
Old Feb 28, 2002 | 07:18 PM
KNONFS's Avatar
B O R I C U A
I had the same problem, and here is the solution:
1) Disconnect the cable from the sender and apply ground to the cable. The needle should rise!
If not:
2) Disassemble the gauge cluster, and pay attention at how the gauge works on the backside (mechanism).
The mechanism is a needle that moves up down, when this needle moves it pushes a white plastic rectangular part. This white plastic rectangular part is the opposite of the needle that marks the oil pressure. Now if the back needle disengages from the white plastic rectangular part, the needle on the front will not move at all!
Any questions?
Old Feb 28, 2002 | 07:29 PM
HAILERS's Avatar
HAILERS
THIS
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
