Need help with making a decision for my FD
Old Aug 31, 2006 | 09:43 PM
spoolin1012's Avatar
I am undecided on what I should do for my FD, I got hit and messed up my front right fender and front bumper. I am stuck between buying the stock bumper, 99' bumper, and any other front bumper, but mainly between the two. My car is daily driven so any fibergalss bumper will probably be distroyed in a week. What do you all think. Pics of my car below
Old Aug 31, 2006 | 09:55 PM
RA8225's Avatar
Banned
If you have the money go 99 spec.. If not.. just put a 99 spec lip on the stock bumper
Old Aug 31, 2006 | 11:09 PM
cabaynes's Avatar
Old and grumpy
OEM 99 Spec with the plate.
All those replicas that have the plate-holder shaved off look horrid.
Your car would look fantastic with a OEM 99 front, after that the exterior is DONE. (except maybe some OEM sides later)
Old Sep 1, 2006 | 12:08 AM
RX7_Fanatic's Avatar
R.I.P. DAVE
+1 for 99 plated, you already have the wing, and the wheels would compliment it nicely
Old Sep 1, 2006 | 02:06 AM
1badd7's Avatar
99 for sure! Looks awesome without any sideskirts. James
Attached Thumbnails Need help with making a decision for my FD-picture078-vi.jpg
Old Sep 1, 2006 | 07:42 AM
SayNoToPistons's Avatar
Insane Burning Diarrhea
^ +1 .. or 99spec with 99 lip unpainted and feed side skirts.
Old Sep 1, 2006 | 12:42 PM
I just got back from the insurance people and they gave me 2k to work with. They didn't want to include the bumper since its plastic and could be fixed. I want to track my car so i might go with the 99' just because it has the bigger openings. Does anyone know if i can get a secound license plate for a state that doesn't require a second plate. I think it will look nicer then a rx7 plate. I was also looking to put apexi sideskirts on, there cheaper then the 99' sideskirts and they look almost the same, what do you think?
Old Sep 1, 2006 | 07:19 PM
cabaynes's Avatar
Old and grumpy
Don't put a second plate on the front if you dont have to. Buy one of the black RX-7 plates... at least I would.
The apexi sideskirts are nice if you dont want to go oem. the Feed sides are nice too-
Old Sep 1, 2006 | 07:47 PM
Yes!! Painted front 99spec lip on a 99spec bumper + apexi lip = the best painted combo!!
Old Sep 2, 2006 | 12:17 AM
Does anyone know anything about the rebar on the 99' spec bumper. Is it needed? Whats the diffrence with or without it?
Old Sep 2, 2006 | 12:23 AM
seven lust's Avatar
it is not needed if you do not mind cutting the existing rebar? I just did not think the money for one was worth it at all... I did the install myself and the fitment is great...
Old Sep 2, 2006 | 01:01 AM
What do you cut on the factory rebar to make the 99 fit, the turn signal light?
Old Sep 2, 2006 | 01:17 AM
seven lust's Avatar
alot of people hack off the ends of the rebar to make it a fast and easy install... but I cut the top half of the turnlamp holes on the rebar to where the back of the 99 spec bumper will slide into that part I cut... does that make since ?...I also cut out an opening in the front of the rebar.... once the bumper was lined up, I traced out the size of the opening from the bumper to the rebar... I then pulled the bumper back off and cut the rebar( THIS IS THE OPENING BEHIND THE LICENSE PLATE) you do not need to do this step.... it takes a lot of mock fitting and pulling it back off to get it right ...but it was worth it...
Old Sep 2, 2006 | 11:00 AM
purerx7's Avatar
Registered User
i daily drove mine for 2 years with a fiberglass feed bumper and havent had a single problem. Even if you had a problem fiberglass isnt rocket science, its really easy to use.
Old Sep 6, 2006 | 01:26 PM
White94RX's Avatar
BMW Tech
What are you guys thinking!?! Front license plates look awful unless you have to have it by law! Don't get the 99 spec unless your having the plate holder removed and smoothed out.
Old Sep 6, 2006 | 02:19 PM
JDMRevolution's Avatar
Make that money!
I personally like the stock bumper with the lip and clear turn signals. mmm
Old Sep 16, 2006 | 09:37 PM
ihavetwins's Avatar
Needs more seat time
are you serious ? but u should get the 99front end plateless it would add to your cars cleaness
Old Sep 17, 2006 | 12:30 AM
cabaynes's Avatar
Old and grumpy
Like a heart attack! Plateless 99 spec fronts look awkward, like a big smile. I despise them.
Old Sep 19, 2006 | 03:33 PM
I ended up putting the stock 99' front end with a pair of 99' sideskirts and rear mudflaps. Im really excited because it looks really good, its going to the bodyshop tommarow so in about two weeks I should have pictures. Thanks for you info.
PS: Now I need assistance on what plate to put on the car. I shaved off all the badges on the car so I dont want to put an rx7 plate (I like to have people guessing). I was thinking about an authetice Japanes plate, or a plain black plate with some rotary depiction on it. Anyone have any simple rotary pic's and what do you think?. Thanks.
Old Sep 19, 2006 | 06:20 PM
KeloidJonesJr.'s Avatar
strictly business
and some FEED sides.
Old Sep 20, 2006 | 09:33 AM
ptrhahn's Avatar
I don't think so:
It's the same shape mouth opening with and w/out the blate brick.
Attached Thumbnails Need help with making a decision for my FD-99_nose_2.jpg   Need help with making a decision for my FD-img_2112_std.jpg
Old Sep 21, 2006 | 12:11 AM
93rx7mcp's Avatar
plate bumper looks funny to me 2. W/ plate looks alot better to me.... im doing one with Apexi sides goes in for paint soon.....
Old Sep 21, 2006 | 08:38 AM
ptrhahn's Avatar
You guys are nutz... it's the SAME SHAPE. It "smiles" with and without.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
jsesq
27
Sep 25, 2015 11:10 AM
