front camber adjustment on stock FC?
Old Aug 31, 2006 | 09:19 AM
coldfire's Avatar
ERTW
I am about to install a new set of KYB AGX shocks and Tanabe springs. so i will still be using the stock mounting blocks.
I am reading the FSM, and there is a way to slightly increase camber/caster. but i'm not entirely clear on the method of doing this, i want to be fully sure before doing this.
it says, and i assuming this is with everything installed, to rotate the strut so that the mounting block is in a different position.
now, since there are 4 bolts, i can put it into 4 different positions, or 3 different positions from stock.
it gives the following chart:
RIGHT
BA
C.
LEFT
AB
.C
this is how the stock position is. now, by rotating to either A,B,C you change the camber and/or caster:
A- 0 camber, 30' caster
B- 30' camber, 30' caster
C- 30' camber, 0 caster
Now, what i don't understand is when they say 30', is that more or less camber/caster?
Old Sep 1, 2006 | 12:09 AM
RETed's Avatar
30' = 30 "seconds"
60 seconds = 1 degree
So, 30' = half a degree
Oh, and that's inducing more camber or more negative camber, so technically it's -30 seconds.
-Ted
Old Sep 1, 2006 | 04:42 AM
Josh18_2k's Avatar
just look at the top of the strut- it isnt centered in the mounting block. so twist it around so that the strut top is closer to the center, and leaning back. basically, have the strut tops closest to you the driver.
Old Sep 1, 2006 | 09:02 AM
coldfire's Avatar
ERTW
ok, thanks for the info. it's in seconds, i see now.
so, changing it to position "B" will give me -30' camber? is that -30 caster also? i don't want to reduce my caster, i want to increase it...
Old Sep 9, 2006 | 07:41 PM
Nova7's Avatar
No, it increases the castor by 30'.
Old Sep 10, 2006 | 01:04 AM
coldfire's Avatar
ERTW
alright, thanks for the info guys. i wish the FSM was a little more clear about that. but, i guess i could have worked out the suspension geometry change myself, haha.
matty
Jan 18, 2020 10:39 AM
RaY358
Aug 19, 2015 11:44 PM
JIMMY54
Aug 12, 2015 05:40 PM
