ignition gets hot and cuts out under light load
Old Aug 9, 2006 | 12:50 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
car-87 turbo 2
mods-
3" exhaust
blow off valve
boost gauge
block off plates
reground alot per mazda tech
rewired power wire from altenator to battery
greddy pro-fec b type-s
new secondaries 550 cc
symptons-
car stutters under loads
ignition feels like it cuts out under load after temp is hot
cant rev past 3.5 k in gear except when cold engine and first gear only
goods-
daily driving is good til engine is warm
turbo boosts fine
bad-
i cant drive my car the way it was meant to be.....
Old Aug 9, 2006 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
Is it the ignitors or coils that get hot? Because it's normal that they do since they tend to sink a lot of current...
Have you checked the standard stuff like TPS, pressure sensor (ground) and CAS?
Old Aug 9, 2006 | 10:28 AM
HAILERS's Avatar
HAILERS
A car that runs good cold, but once warmed up has some meaning to me. When cold, and you look at a wideband, you'll see that the afr's are rich. Once the engine gets a little warn, somewhere around 120 degrees, the afr goes richer by about one afr point. Say from 12.0 afr to 13.3 afr (just an example).
So I'm thinking that once fully hot, your not getting enough fuel. Why? Got me. Throw some more money at the car and buy a wideband to see the afr. If you have a laptop, a Zeitronix might do. It's cheaper without the display and you could look at the laptop for the reading.
Old Aug 9, 2006 | 12:05 PM
j9fd3s's Avatar
Community Builder
along those lines it could be a bad coolant or air temp sensor, maybe the secondaries dont work. bad fuel filter? pump?
Old Aug 9, 2006 | 12:35 PM
RotoriousRx7
1.well new fuel filter
2. i have a air fuel guage and it goes lean if i floor it and if i ease in to the gas it goes rich
then lean
3.as far as the pressure ground goes i have tried to reground but it made my indash
gauge not work so i think i cut a reference wire but per the diagrahm its right
4. also is there a place to buy a brand new engine harness
5. also anyone have the link to a website for the injector pigtails so i can do that too..
Old Aug 9, 2006 | 12:39 PM
RotoriousRx7
oh sorry aaron
that i dont know it just feels like an ignition problem from experience with other cars and
the way it feels when it cuts out , do coils and ignitors go bad often
and it also has a hard time starting after being warm up
it will only start if i hold throttle wide open while cranking even then it barely comes to life
and just takes a second to rev up then all is fine til you let off the gas then almost dies
\idles low
Old Aug 9, 2006 | 01:25 PM
My5ABaby's Avatar
Rotaries confuse me
Have you done a compression check?
Old Aug 9, 2006 | 02:18 PM
mort2002's Avatar
well, i wam thinking he is running lean too, with 3" ehaust. what is your boost at? that could be an issue too, do you have a fuel cut defender? with 550cc injectors you cant push over like 11psi from my experieces.
Old Aug 9, 2006 | 03:30 PM
HAILERS's Avatar
HAILERS
Your words about the Boost/Pressure sensor (I guess) is worrysome. IF grounding the boost/pressure sensor on a series four, you ground the brown/black wire. ON some later cars it's a pure black wire. NEVER gnd the brown/red or the brown/white (I mean NEVER EVER THAT ONE). If you do, you chance whacking the ECU and or pressure sensor.
Old Aug 10, 2006 | 12:38 PM
RotoriousRx7
thx hailers ill dub check that
but no fuel cut defender yet
boost stays at 5.5 on the aftermarket guage
i have tried a fuel cut defender, it did jack ****
and no to the compression check
Old Aug 14, 2006 | 01:12 AM
RotoriousRx7
any other suggestions?
Old Aug 14, 2006 | 01:46 AM
papiogxl's Avatar
What's the point??
Try switching out the leading coil, I just did this on flaresniper's RX-Sa7mon today and it fixed a problem that sound exactly the same. Bheiman also had this sort of problem with two other cars of various makes and this remedied it.
C. Ludwig
Jan 30, 2019 06:31 AM
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
