TD06-20g and 60-1 dyno info?
Old Aug 8, 2006 | 03:04 AM
I am trying to find some decent dyno results from these two turbos. Not really looking for peak # possible, but spool time.
I am looking for the best response turbo to get me ~325whp, so if there are better options, by all means please point me in the right direction.
*edit* this would be on a stock port s4 motor with all the normal needed/expected bolt-ons*
Thanks much!
Old Aug 8, 2006 | 03:13 AM
mods, if this needs to be moved to a better location please do. I search and didnt find what I was looking for
Old Aug 8, 2006 | 03:16 AM
Nihilanthic's Avatar
moon ******
Just a lil bit of theory here...
With stock ports youd need to bump up the pressure ratio to huff more air through them vs bigger ports, which means you need a efficient turbo, and/or a good FMIC. Alky injection could be helpful as well.. and for gods sake get a standalone, man.
From what little information I've gotten from the FC CPU, its junk. Personally I'd go with MS because its not ridiculously expensive, but thats me.
Also, supposedly someone got 400 whp from a stock S4. I forgot where the thread is, though.
Old Aug 8, 2006 | 04:09 AM
kenn_chan's Avatar
Savanna Rx-7
I remember that one, it was with a Hybrid turbo. hitachi hot side with a to4e compressor and wheel ported wastegate etc.
The 20 G will spool pretty quickly, maybe a little restricitve though, it seems that most of the guys looking at 06's are useually looking for the 25 g housing instead.
kenn
Old Aug 8, 2006 | 11:42 AM
Thanks for the info guys.
Plans are for a haltech or microtech
car will have the standard front mount or a fab'd vmount
fuel pump, bigger primary and secondary etc etc. All the must do's.
Old Aug 8, 2006 | 11:42 PM
rarson's Avatar
The TD06-20g is on average a 350-375 whp turbo on a 2.0L DSM. Sure it might reach your horsepower levels, but at the level it'll probably be wheezing pretty good. I like Mitsu turbos but they are so outclassed these days by newer technology. They are pretty much cutting edge for 1970. I'd recommend a 60-1 hands down, or better yet, something GT-series.
Old Aug 9, 2006 | 08:02 AM
RETed's Avatar
Stay away from the Mitsubishi stuff, especially when using low boost levels (i.e. under 15psi).
The design does not running really low boost.
-Ted
Old Aug 9, 2006 | 09:29 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
how so?
Old Aug 10, 2006 | 12:19 AM
No_Rotor_RX7's Avatar
get a GT series turbo... hands down the most efficient out there. especially if you're only looking for 325 - 350rwhp. GT35R will handle that with ease on a pump gas tune. WOOWOOOOOOO!!!!
Old Aug 10, 2006 | 02:51 PM
What about spool and response?
Old Aug 10, 2006 | 08:17 PM
Manolis_D's Avatar
hell with a GT series turbo, UNLESS it's a 35/40. The compressor map for the 60-1 is just about PERFECT for a 13B running 12psi of boost (i.e. 330rwhp). Use a 60-1 compressor, P-Trim exhaust wheel, and something like a .84 divided exhaust housing, or maybe even one size down for crazy spool.
You will NOT be disappointed =)
-Manolis
1990 RX-7, 60-1 compressor, .84 divided hotside. fun.
Old Aug 10, 2006 | 08:21 PM
Manolis_D's Avatar
Best you will find out there for this power range. If you can afford the extra 400 bucks (GT35R is the same as the 35/40, and they run about US $1300 IIRC, while the T4 60-1's are about $900), go for the GT35R. probably 500rpm earlier spool, and faster transient response with the same power potential. nice =)
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Rotate86
May 18, 2018 02:44 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
