Sponsored by: CARiD
can hold fan still ??
Old Jul 30, 2006 | 02:00 AM
bigtrevdogg's Avatar
well my car over heats if i go fast allot but i can hold my fan still while its running and it has a bearing on it so when i rev it it dont go ne faster the fan moves slow when reved and the pulley is slipping on the belt is this why iam over heating do u think are ne of these things normal ??
Old Jul 30, 2006 | 02:25 AM
Mireck 12A's Avatar
Racingbeat dealer
The 1979-1992 Rx-7's have a visco clutch fan. You should be able to hold it still if the engine is cold (even then wear gloves )
it will rotate when the engine is cold but can be hold.
When is the car overheating, more information is needed for people to be able to give you some tips. Type Rx-7, year, ect ect.
In general:
Overheating when cruising : check to see if you got a plastic undertray,radiator blocked or clogged.
Overheating when idle: check waterpump belt, fan clutch,pressurecap, and look if there are bubbles in the coolant (blown waterseals)
good luck,
Mireck
rotor_veux
Sep 19, 2015 07:13 PM
Blastfastrotary
Sep 11, 2015 12:26 AM
RotaryBobby
Sep 10, 2015 01:33 PM
