15"'s on a Tll
Old Jun 15, 2006 | 06:17 AM
87cncnu's Avatar
Arrow 15"'s on a Tll
OK...so previous posts have given me info on lightweight wheel manufacturers for track use. Will use '225' RA-1's all around. Question is should I go with 15"'s or 16"'s?
Seems to me 15" wheels and tires , will be lighter, cost less, and offer far more selection (wheels). Other issue is tire diameter will be about 1" less than'stock' (225/50-15 vs 205/55-16), effectively giving me lower gearing...which is maybe not a bad thing for track work.
Anyone see a problem running 15's? Anticipate 15X7 with +32 to+35 offset.....Bistein's leave less clearance inside, so I have to push them out a little (+40 rubs the coilovers up front).
Old Jun 15, 2006 | 09:54 PM
Secondmessiah's Avatar
Rotary enthusiast
in my opinion, 15" would look cheap/bad enough to make up for any benefits
but thats just me
plus, if you want to keep your car the same height, you would need to get higher profile tires
remaining at stock size also allows the advantage of interchangability, you could could have a set of winter tires and summer tires on a set of rims each
Old Jun 16, 2006 | 02:03 AM
ShadowX's Avatar
For the track, you're going to want 15"s, a lot more tire sizes available. Otherwise, go with 17's. Personally, I really like 16's on my TII, but finding good tire sizes is a PITA.
Old Jun 17, 2006 | 06:08 PM
87cncnu's Avatar
Not concerned too much with look, as this is for track use (17" with 225/45-17's F1-D3's for the street or wet tracks). Tire size for RA-1's is either 225/50-16 or 225/50-15, with the 15's being $80 (CDN list) cheaper each. Much better selection in wheels in 15 than in 16. And then there's the weight.
Still thinking I adjust the Bilsteins to give me room to get the jack under the car with the 15's, and live with al ittle more 'eyebrow with the 17's.
MichaelXMorris
Dec 1, 2008 12:44 AM
pittbulls
Apr 3, 2006 08:07 PM
12aPwr
Jul 10, 2003 07:46 PM
Pacey3182
Dec 12, 2001 11:21 AM
