Tial wastegate install
Old Jun 10, 2006 | 10:20 AM
FD3S_wanted's Avatar
Hi,
I have a 40mm Tial wastegate. On the installation diagram it says: Wastegate air control side port connection. Supply air from intake manifold, before throttle plate.
The BEFORE THROTTLE PLATE, is that really important? Did you take the vacuum/boost source before the TB ? I thought it was directly on the intake manifold.
Thanks!
Old Jun 10, 2006 | 10:36 AM
dhahlen's Avatar
FD Under Construction =P
The two nipples on my HKS wastegate are 1.) Boost/Vacuum source (on the UIM), and second nipple goes to boost controller solenoid.
Old Jun 10, 2006 | 12:14 PM
C. Ludwig's Avatar
www.lms-efi.com
Originally Posted by FD3S_wanted
Hi,
Thanks!
You can source the line from either the intake or the compressor cover. There are pros and cons to each but doesn't really matter.
Old Jun 10, 2006 | 12:15 PM
Crusader_9x's Avatar
If you put the side nipple on a source after the throttle body then the boost could spike on you. Where as if you route the side nipple to a source before the throttle body you will get a much stronger boost signal.
Old Jun 10, 2006 | 01:31 PM
Thanks for answers guys!
I have a 13B-RE, I don't think I have a nipple before the TB. Did you tap some kind of nipple ?
Old Jun 11, 2006 | 04:55 AM
NeedFD's Avatar
R. R. R.
I've seen some people tapping the actual turbine too, (cold side) honda guys mainly
Old Jun 11, 2006 | 11:48 AM
Thanks but I will not do that :P
Old Jun 12, 2006 | 10:31 AM
NeedFD's Avatar
R. R. R.
wise decision
Old Jun 13, 2006 | 08:41 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
atp turbo does make a quick tap. 9 bucks you tap it in the coupler right after your turbo...
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Snook
14
Oct 1, 2015 10:56 AM
Skeeg
Sep 5, 2015 07:41 PM
