West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
My 90 TII failed the smog test today in Fresno, CA.
Old Jun 9, 2006 | 03:50 PM
Eternal_Gamer's Avatar
Here are the numbers:
(HC)
15 mph: Max=121 Ave=31 Meas=44
25 mph: Max=96 Ave=20 Meas=34
(CO)
15 mph: Max=0.76 Ave=0.10 Meas=0.01
25 mph: Max=0.65 Ave=0.09 Meas=0.01
(NO)
15 mph: Max=807 Ave=237 Meas=990
25 mph: Max=746 Ave=199 Meas=815
Everything else passed except: (Ignition Timing: A99) (System Malfunction Light)
This really sucks, because I only got til the end of this month and I work Monday-Friday 9-5 so i never have time. I am also running low on cash at the moment. I need to find out what is malfunctioning, but I dont want to pay $50 for a diagnosis. Can anyone tell me how to check the engine code the other way. I searched and couldnt find it. Also I dont understand the ignition timing, why would did that fail. So what could cause the high NOx. Right now this is my setup:
S5 Jspec motor All stock including exhaust with precat, main cat, split air pipe connected. I did a recent oil change too with Royal Purple 20w50 spark plugs have about 3000 miles on em.
N370 MAF
S5 TII Air Pump
N370 ECU
N370 Boost Sensor
N370 Harness
N374 BAC
JDM ACV
JDM Intercooler and JDM Upper Intake Manifold and throttle body
Old Jun 9, 2006 | 06:49 PM
RevUp13b's Avatar
zZzZzZzZzZz..............
check FAQ, they have a pretty good guide to these this... look for the chart
Old Jun 9, 2006 | 07:13 PM
okay well the faq says according to my results, I have an EGR, lean air fuel ratio, leaks, run-in converter, use larger converter. Well, the S5 TII doesnt have an EGR. lean air fuel ratio, cant be, because I am running off the stock ECU with no mods. leaks? Vacuum leaks or Exhaust leaks? I don't know what a run-in converter is. And last but not least, why would I need a larger converter when im all stock, and if i do need one, what bigger converter is good? And the FAQ still doesnt answer my ignition timing problem. and i cant find how to check for engine codes without a diagnostic computer.
Old Jun 9, 2006 | 09:28 PM
Icemark's Avatar
sounds like you are running lean, has the air fuel ratio vairable resistor been tweaked???
either that or your main cat converter is failing
Old Jun 10, 2006 | 01:14 AM
Where is the air fuel ratio variable resistor? Its supposed to be by the passenger side shock tower right? I see nothing but a Boost sensor in that area. What does this resistor connect to? The main cat converter has passed 4 cars already recently with good low #s and is never driven on daily and only used for smog, so I doubt thats the problem.
Old Jun 26, 2006 | 01:27 AM
veryslow7's Avatar
do what i did and weld an extra cat between the precat and the main cat. i had the same problem and that what i did. so yes i do have 3 cats when i do smog. well worth the money. good luck man
Old Jun 26, 2006 | 01:43 AM
aram's Avatar
Easiest way to get the sucker to pass... cats are so cheap now that it's worth having a new one on there.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
SCinfidel
Sep 8, 2015 05:36 PM
whinin
Sep 5, 2015 11:52 PM
gabescanlon
Sep 5, 2015 12:04 AM
