What's this turbo?
Old Jun 6, 2006 | 12:23 AM
Carzy Driver's Avatar
Law Breaker
What's this turbo?
I just got a new AiResearch T04B08 turbo for next to nothing. It's a .60 compressor and a .69 turbine. what does those numbers mean and is that any good? planning on using it in my FC if I can't get this other turbo, a T04E, whatever that is... heard the E is better than B??
Is there any good guides I can learn info about turbos from?
Thanks
Old Jun 6, 2006 | 01:37 AM
RETed's Avatar
Pop the compressor housing off and measure the major and minor diameter.
Post the numbers...
-Ted
Old Jun 6, 2006 | 02:30 AM
Law Breaker
compressor major: 2.748 in
compressor minor: 1.840 in
have yet to measure the turbine but will do so later today
Thanks -Dave
Old Jun 6, 2006 | 04:07 AM
RETed's Avatar
http://fc3spro.com/TECH/TURBO/tmodels.html
Closest thing is a T04B S-trim?
If so, this is basically the same size as the stock Hitachi HT-18 on the FC turbo.
-Ted
Old Jun 6, 2006 | 12:03 PM
Law Breaker
ok, not that bad than, for 25 bucks. what does s-trim or p-trim mean? just an easier way of describing the turbine wheel?
Old Jun 6, 2006 | 01:39 PM
RacerXtreme7's Avatar
NASA geek
You need to do some research on tubos before you waste too much money on one for your car. The turbo you have is way way too small for a rotary. Its a $25.00 paper weight, even Honda guys go for something bigger. S trim referes to your compressor wheel and P trim is a turbine trim. Theres many trim levels per family (family would be T25, T3, T4, T6 etc.). Trim is a ratio of major and minor wheels either described in numeric form (such as a 57, or 60 trim) or in alpha numeric (S-trim, H-trim etc). Turbines in general use alphanumeric (such as N,O,P,Q trims).
Theres a wealth of knowledge on the net and this forum in particular. Search, read and get your learn on.
~Mike............
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
