Turbo need reclocking?
Old May 29, 2006 | 06:31 AM
mr2foryou's Avatar
600+rwhp club member
My GT40R is blowing a little oil out of the back of it and I am wondering if it is because the oil feed and return are in about a 10 & 4 position. Shouldn't they be in a 12 & 6 position? Vertical. Could them being in a 10 & 4 cause oil to back up in the turbo? Please help, I am trying this last step before sending this new unit back to Garrett. It does have a restrictor fitting in place. Thanks
Dee
Old May 29, 2006 | 11:57 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
a little bit of an angle won't hurt anything, but as close to vertical as you can get it is best.
Old May 30, 2006 | 12:21 AM
Asleep's Avatar
7 Rx-7s since 1980
Not more than 5 degrees off the vertical for the oil drain. The oil feed is just along for the ride...since its pressurized, it is moot.
I hope you're not using the rubber hose for the oil drain.
Who did you purchase the kit from? If it doesn't have an oil restrictor and you've had oil pressure mods done to the car, you will need a restrictor. No mods, no restrictor would probably work.
Oil drain needs to be kink free, as big a braided hose you can get down there, and a smooth path to the oil drain. AN-10 or even better AN-12. The first 6 inches down off the turbo should be as straight down as possible. Blockage here will push oil into and out turbine discharge and into the exhaust.
Depending on porting on your engine, the specs on the turbo, and tuning you should have 18psi at ~4200rpm. Higher if you can tune for it.
Old May 30, 2006 | 02:18 AM
-12 would be cool, but you'd have to do some machining to the front cover to get it to work properly. fd drains are small. (obviously, there were 2 of them stock)
Old May 30, 2006 | 06:19 AM
mr2foryou's Avatar
Thanks guys. It does need reclocking then. And I do have a -10 rubber hose on it. Guess I will need to get rid of that.
Old May 30, 2006 | 11:42 AM
mark57's Avatar
Temple of Cornd0g
You need to maintain an I.D. of 5/8 inch for oil drain/return line. You can do this with -10 metal fittings and -12 line. -10 line will not fit onto -10 fittings; -10 line is too small for -10 fittings.
Stock turbo unit has two 5/8 inch I.D. drain lines b/c it has two independent turbos - not b/c the two oil drain lines are "undersized".
Old May 30, 2006 | 12:12 PM
the stock returns are ~.59, not .625
Old May 30, 2006 | 01:49 PM
mark57's Avatar
Temple of Cornd0g
I stand corrected; the o.d. of the thin wall tubing of the factory oil drain is 5/8" which obviously renders the i.d slighty smaller. Because -AN sizing is all about O.D. of hard metal line, mr2foryou still benefits by fabricating his oil drain using a minimum of 5/8" I.D. as a lesser -AN size will not only not fit, but will not afford the oil drain flow required of his turbo.
Old Jun 2, 2006 | 09:26 AM
rarson's Avatar
I'd have to say that I agree you should reclock the turbo to 12 and 6. Ball bearing turbos are extremely sensitive to oil flow.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
