lean tip in.....
Old May 25, 2006 | 12:34 AM
Rotor Nut.
lean tip in.....
getting a slight stumble and lean tip in with my new setup. i have 550/1600's. i did some searching but couldnt find the cause of the leaned tip in. its very slight. it goes lean real quick then its fine. any help appreciated.
Old May 25, 2006 | 01:26 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
pressure drop when the 1600's come online.
Old May 25, 2006 | 01:40 AM
Rotor Nut.
i get it at 2500, 3000. i dont really notice it at 4k+. dont the sec only come on at 4k..
Old May 25, 2006 | 03:09 AM
jacobcartmill's Avatar
just dont care.
they come on with load.
Old May 25, 2006 | 06:40 AM
dhahlen's Avatar
FD Under Construction =P
Yup, if you have a power FC, and access to a datalogit - you want to add roughly 3-8% fuel in the whole N06, N07, N08 - I did 4% in N06, 8% in N07 and 3% in N08 rows, assuming your P&N settings are default. If you have a datalogit, I can walk you through it - pretty simple.
Old May 25, 2006 | 09:24 AM
Rotor Nut.
yea i have a datalogit. ill try adding the 3-8% through N06-N08.
Old May 25, 2006 | 09:49 AM
CCarlisi's Avatar
Rebreaking things
I would add fuel to the accel enrichment first. Your description makes it sound like it happens when you change the % the throttle is open. Set the map to be ideal for steady state and play with the accel values to compensate for sudden movements of the throttle. That is how I tuned my car. It will give you the best mileage and should take care of the problem.
Old May 25, 2006 | 11:27 AM
Rotor Nut.
also what is good safe cruise afrs? i have it in the 16's right now on criuse. i am thinking of bringing it to 15's.
Old May 25, 2006 | 07:28 PM
dhahlen's Avatar
16s are super lean, you want it anywhere from 15 to 12.
I like it around 14.3 - but as it sits right now, its like 12.5 lol. But I haven't messed with my lag to fix it, its safer stupid rich anyway.
Old May 25, 2006 | 07:36 PM
twokrx7's Avatar
Need more sleep
I ran 16 AFR's and up in cruise, great for keeping plugs clean!
Old May 25, 2006 | 07:48 PM
dhahlen's Avatar
ouch, that sounds pretty lean to me... i always get iffy when i see 15's =P ESP under boost!
Old May 25, 2006 | 08:09 PM
leaner doesn't necessarily mean better gas milage. it does to a point, then th engine starts getting less efficient.
2 things that really effect how lean you can realistically run it are port overlap (the less the better), and compression (more the better).
other than that, negative split is fun to play with for firing off super lean mixtures. i've run my fd all the way to the high 16's before it would miss, but i could feel the power dropping off when it got much leaner than the low 15's and i had to use a higher pedal position to maintain cruise.
darren, under cruising conditions...say <4krpm and 8"+ vacuum, the engine will misfire before it detonates.... actually, (now that i think about it) if you can MAKE it detonate under those conditions, i'll give you a cookie.
Old May 25, 2006 | 09:04 PM
dhahlen's Avatar
Dave, I wasn't worrying about detonation under cruise. You show me someone that blew an engine from cruising or letting it idle and I'll show you a man with 8 *********.. gross.
I just don't like running that lean period... not in cruise, not ever... but thats me. Before the kan tune, my cruise was 15.0-14.7 which yielded pretty good gas mileadge. Now with Steve-O's rich tune.. I get crap mileadge, but I don't care. LOL
Old May 25, 2006 | 09:12 PM
CCarlisi's Avatar
Rebreaking things
I run 15.5 at crusing speed and haven't had a problem with it. I used to drive a 480 mile road trip once every 2 weeks. My mileage was 22-24 mpg and I typically cruise at around 75-80. Near the 0/0 vac/pressure row my afrs are in the 12s.
I think the chance of doing any damage in vac at low rpm is remote. When I did my first engine swap several years ago my friend that was *helping* me hooked my ignition coils up in the wrong order. Believe it or not the car ran fine but had severe misfire as soon as the manifold pressure became positive. Steve Kan witnessed it. It sounded like someone running nails over a chalk board. If that didn't do any damage I can't see how 16:1 could under light load.
Old May 26, 2006 | 12:41 AM
Rotor Nut.
dhahlen, richend up the n6-8 and the surrounding areas and it worked good. my cruise afrs were a little to lean mid 16's and some 17's after driving today. after richen i got it to mid 14's, which sounds and runs a little smoother and no more lean tip in.
Old May 26, 2006 | 07:06 AM
dhahlen's Avatar
Kewl, glad it worked out for you.
Old May 27, 2006 | 02:02 AM
steve's a good tuner. i don't know why he would richen up the cruise stuff.
Old May 27, 2006 | 07:19 PM
dhahlen's Avatar
It had to be that way because I am running methanol injection. Due to the PFC's limited capabilities (you can only be in a certain area) you can't adjust it low in one area and extremely high in the other. you have the upper and lower limits (bummer) - so when he set the lag to work with the methanol, it made the cruise area run rich. If I were running a haltech, I could run 1000cc primaries and have it work out great... with the PFC - injector lag has a lot to do with it, and it limits the whole map, not just the idle/cruise area.
Also, steve wasn't focusing too much on cruise... just for boost and power. He also tunes for drivability if you ask him. But I was just doing the dyno/power tune.
Old May 27, 2006 | 08:40 PM
throw that haltech on there and be done with the Piece of Fucking Crap
Old May 28, 2006 | 10:25 AM
peejay's Avatar
Old [Sch|F]ool
Were you monitoring fuel consumption? (say something as simple as duty cycle at a given cruise speed)
One of the benefits of EGR is increased fuel economy by decreasing intake manifold vacuum, thereby decreasing engine pumping losses.
Upshot: running at heavier throttle for a given load *might* result in better economy, but only instrumentation could tell for sure. It'd be interesting to see what richer and lower throttle opening vs. leaner but more throttle do for consumption.
Old May 28, 2006 | 01:45 PM
i never got too too deep into the datalogging, but i've done a tank or two of gas running each way, and the current motor (9:1) in the fd (built with spare parts, mind you) got the best fuel economy right around stoic. the new motor actually has all the parts within spec, all new seals, etc... and it has a cosmo primary (they have less overlap, for those of you that don't know).
i was going to use renny rotors and go for big fuel economy, but i realised that 8.5 rotors will save money. with the 8.5 rotors, i'm aiming at 400whp on 87 octane + water/meth just to see if i can do it, but i should have absolutely no problems running it at 10-12 psi on a daily basis...even without the injection. so $.20/gallon is going to save me more money on fuel than the 1/2-1mpg increase from the high-comp rotors.
back to the topic-- not sure what it's going to do for split and economy, but the motor that's in there was intended to be a temporary solution so i could drive the thing. the new motor makes factory compression. that should make quite a bit of difference, even with the lower compression ratio.
if i get a bunch of extra time and money, i'll set the cruise control on the dyno and i can play around with how lean lean i can get it and at what point it loses its benefits. but in order to do that really well, i'd take the vac line off the fpr, then flow test my injectors at that exact psi and duty cycle, to give me a relatively accurate idea of how much fuel it's going through so i can do a rough calculation of the bsfc. but that's a lot of trouble for not a lot of benefit. if i had an engine dyno and a couple weeks to play with, i could get all sorts of data.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
