A couple maintance Tips for the Auto trans people
Old May 23, 2006 | 12:07 AM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
Cleaning Torque Converter (easy)
1: Set the converter on a bench vise
2: Insert a Garden hose into the pilot depression of the converter
3: Put other end of the hose in to a bucket
4: Place an air nozzle in the top of the converter
5: Loosly stuff a rag or piece of plastic around both hoses
6: Apply a small amount of air and it will force out the fluid and dirt
7: Rock the converter back and forth to move the fluid into the pilot well
8: Repeat until all fluid is out of the converter
Flushing Converter While it is in the car
1: Determine which line going to the cooler is the pressure line, and disconect it from the cooler
2: Put the disconected line into a 5 gal. bucket
3: With the engine running and the car in park
4: add fluid to the transmission at the same rate as what is coming out of the line goin into the bucket
5: After about 8 quarts the converter should be fluched
6: Reconnect the line to the cooler
7: Add fluid to fill to proper level
8: start car and check for leaks
**CAUTION** At no point in time during the flushing operation, should the level of the fluid go below 90% full.
Hope this helps some.
Old May 23, 2006 | 12:32 AM
Rx-7Doctor's Avatar
Good write up. To protect the trans add lube guards transmission protectant. It is one of the few additives endorsed by the dealer. Also service the trans every 15k.
Old May 23, 2006 | 01:54 AM
Play Well
Ahh yes I should have said something about transmission fluid. I use and will always use trick shift from B&M
Old May 23, 2006 | 10:12 PM
Play Well
Testing for Ruptured Vacuum Modulator(super easy)
1: Disconnect the Vaccum line going to the carbuator
2: check for fluid in the line
3: If fluid is in the line the modulator needs replaced.
Old May 23, 2006 | 10:23 PM
peejay's Avatar
Old [Sch|F]ool
Find a shop that does a T-Tech service and have 'em do it.
It actually exchanges the fluid, up to 13 quarts.
We charge $90, IIRC. Money *very* well spent, we have customers with so-called "problem transmissions" (like the Chrysler 4-speeds, or the Ford AXOD) pushing close to 200k on the factory transmission, just regular fluid exchanges about every 40-50K.
Old May 23, 2006 | 10:29 PM
Play Well
I just posted it for people that might want to do it themselves. But your post reminds me that I need to go and have all the fluids in my car flushed and refilled at the dealer in my truck.
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
sandy_RE
Interior / Exterior / Audio
Sep 24, 2015 10:37 PM
kenplevy
Sep 4, 2015 10:40 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
