TB Mod induces low idle
Old Feb 15, 2002 | 09:04 AM
Silver88GXL's Avatar
I performed the TB Mod on my GXL, but now the car is idleing REAL Low. Right now, it is at about 500RPM, and the adjustment screw on top of the TB is turned pretty much all the way open. I think it is about to come out!
Anyhow, I did the swap to a spare TB, so I would not mess up the current one, so the settings most likely are different from what was on there before.
Any Ideas as to what needs to be tweeked? I messed with the throttle return dashpot thing and that did nothing.
Thanks
Carl
Old Feb 15, 2002 | 09:15 AM
SureShot's Avatar
Seduced by the DARK SIDE
It sounds like your old TB may have had an air leak around where you did the mod. As long as the idle is smooth, just adjust the butterfly shaft idle stop.
Old Feb 15, 2002 | 10:13 AM
boostmotorsport's Avatar
Yeah my idle is held up by putting tension on the cruise control cable, works great, and I have a ported TB as well.
Old Feb 15, 2002 | 10:33 AM
Not familiar with that teminolgy. Is there another name for the butterfly shaft idle stop or where is the butterfly shaft idle stop.
Thanks
Carl
Hmm, I guess I could do that. No problems with the workings of the cruise control?
Carl
Old Feb 15, 2002 | 10:45 AM
SureShot's Avatar
Please excuse the old-school carb terms. The upper throttle shaft has a mechanical rotation stop just under the forward end. It has an adjusting screw and is secured by a jam nut.
Old Feb 15, 2002 | 01:49 PM
Felix Wankel's Avatar
Super Newbie
Do it the ghetto way and tighten up the throttle cable. I wish I'd never done the TB mod now.
Old Feb 15, 2002 | 02:55 PM
HAILERS's Avatar
HAILERS
The tiny screw two inches to your left from the largest blue hose: http://www.rhichome.bnl.gov/People/s...rottlebody.jpg
Kyo
Apr 13, 2019 09:24 AM
msilvia
28
Apr 14, 2016 12:58 PM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
