How To: Repair the hatch lock
Old May 17, 2006 | 11:39 AM
aussiesmg's Avatar
Thunder from downunder
Talking How To: Repair the hatch lock
I have two FBs with the same problem thought I'd share an easy fix with you guys.
The rubber that isolates the latch shrinks with age and allows the latch to move about causing locking problems, some can be adjusted and tightened but i decided to fix it once and for all.
Remove two large retaining screws and remove both top and bottom plates. Each plate has a rubber gasket insulating the metal from the glass.
The rubber that protrudes into the glass holes is the one that shinks.
Cut the two pieces of rubber that extend into the glass holes off.
I had a piece of silicone heater hose, but regular will do, cut 2 pieces of about 1/4" length, slide them into the glass holes. This hose was an exact fit, couldn't be luckier.
replace the remaining stock items, the metal posts will take a little coaxing but will go into the heater hose nicely. Tighten and test the lock works. Now my latch wont move at all.
I found I had a problem with the striker so removed the rear trim, loosened the catch panel and raised it about 1/4".
Now my latch is secure, I can close and lock my back hatch, it doesn't jump open over dips, rattles are vastly reduced as is exhaust sound (well a little bit)
Steve
Old May 17, 2006 | 04:52 PM
IanS's Avatar
Ricer
What is diameter of hose? Nice writeup. My new subs like to open my hatch while going down the highway.
Old May 17, 2006 | 04:57 PM
aussiesmg's Avatar
I had to go out in the rain just for you Ian. LOL
5/8 OD and 3/8 ID.
trochoid's Avatar
Old Fart Young at Heart
My first question for both of you is what kind of shape is the hatch weatherstrip in? As that ages, and shrinks, it can affect the tightness of the latch too.
Steve, you're just full of ideas today, aren't you.
Old May 17, 2006 | 04:59 PM
aussiesmg's Avatar
Mine is in pretty good shape actually, strip has no rips and is standing up to useage. It looks as though it may have been replaced and that's why i had to raise the catch.
Old May 17, 2006 | 05:05 PM
Siraniko's Avatar
RX for fun
thats a good idea with a hose so the bolt doesnt move at all. I never thought of that. thanks meng
Old May 18, 2006 | 01:02 AM
blwfly's Avatar
kiwi from downunder..
this should go to arcives for futur refernce i may need it my latch is movin when i cleaned the car
awsome mate
Old May 18, 2006 | 01:54 AM
rxtory's Avatar
Roll to Heaven in a RX-7
damn i want that............teenager talkin
Old May 18, 2006 | 06:20 AM
IanS's Avatar
Ricer
Its just a couple of nice 10s in a nice slot ported box with a nice 900 watt amp.
Old May 18, 2006 | 04:42 PM
aussiesmg's Avatar
Originally Posted by blwfly
awsome mate
It was an easy fix but works like its a new lock.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Coochas
Oct 3, 2015 04:49 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
