Haltech Question on the FD stock fans Setup
Old May 14, 2006 | 11:41 AM
Indian's Avatar
It wasn't me!!
Ok Gentlemen, Heres My problem. I want to hook up my stock fans in my FD. I no longer have the stock wiring harness(not that it would help,being a 2000 model No pinouts for that wire loom). So how to I do It then? I've read some other posts and most of them have been left unanswered or questionable. I need to know how to set up the relays and how to trace the wiring either inside the car from the relays or just how to really hook up the pwm to get the fans running.
Thanks GUys, Some someone can help.
Keith
Old May 14, 2006 | 01:57 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Keith
The PWMs will be your grounding side, so, what you do is wire up the negative of the Fans to ground, and the positive to a relay connected to the battery. Your PWM will be connected to the Gnd on that relay thus closing the circuit when your temp is met and activating them.
Old May 14, 2006 | 10:17 PM
Indian's Avatar
It wasn't me!!
Thanks Claudio, but I want to use the stock relays that are in the car. I don't wanna gut anything more out. If it comes to it, I'll do what you said though. Thanks
Old May 15, 2006 | 11:06 AM
crispeed's Avatar
'Tuna'
Which Ecu are you using?
The reason for asking is because with the E-8/11 you can control the various speeds at various temperatures the fans were designed too operate with from factory plus these ecu's will turn on the fans once the A/C is activated as long as it was set up to do so.
If it's an older series haltech then it's up to you to decide how you want them to operate. Also are you going to use the A/C?
The factory setup consist of three speeds one of which is activated by the A/C relay, the other by the ecu and the last one from the thermo switch. That's just a rough explaination of the setup.
Old May 15, 2006 | 12:47 PM
dubulup's Avatar
development
Damn, I hate hearing more about the E-8's
https://www.rx7club.com/showthread.p...highlight=HINT
this will help out some if you have an E6_ model
Old May 18, 2006 | 09:11 AM
Indian's Avatar
It wasn't me!!
hey guys, which one of the relays are for the high speed. Think I'm gonna run a pwm to the high speed relay and that should work.
Also , what abou the a/c, any know how to hook it up?
Old May 18, 2006 | 05:00 PM
dubulup's Avatar
development
there is a combination of relays that need to power the fan motors to get it on high. workshop manual is your friend.
Old May 19, 2006 | 09:57 AM
Indian's Avatar
It wasn't me!!
Anyone has instructions on how to do this. I don't think the workshop manual tells you how set this up
Old May 19, 2006 | 05:41 PM
crispeed's Avatar
'Tuna'
Once again which ecu do you have? I'm asking this question for a reason.
As for the A/C you have to bridge two wires under the dash close to the passenger side kick panel for it to function properly. Basically one of the wires came from the blower control/thermostat switch to the factory ECU which depending on certain conditions the ECU would then trigger the other wire which is connected to the A/C relay.
Old May 21, 2006 | 01:24 AM
Indian's Avatar
It wasn't me!!
oh sorry crispeed, I have the e6x
Old May 22, 2006 | 12:39 PM
dubulup's Avatar
development
Yes it does, but here let me "de-code" it for you
The heater control unit GND's relay No. 1 to transfer power to the fans.
The PCM GND's relay No. 2 and No. 4 to transfer power to the fans.
The thermo switch GND's relay No. 3 to transfer a second GND to the fans.
My guess is if you GND all three of the above red lines, you will get fans on HI speed.
You can straight up GND relay No 3. as an extra ground will not run anything thing with the ignition on. Get creative and tie the heater control unit's wire and ECU wire together and hit them with a PWM wire from the Haltech.
Old May 22, 2006 | 08:37 PM
Indian's Avatar
It wasn't me!!
Nice crispeed, Ok now what about the a/c? any info on that?
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
