Sponsored by: CARiD
HELP! Oil Metering Pump
Old May 8, 2006 | 08:21 PM
Davids93FD3S's Avatar
So on my 91 N/A i was told my Oil Metering Pump was bad, and i have no clue what this does or anything. The mazda dealership told me it was going to cost like $1500 for the part! Is this true? Thanks David
Old May 9, 2006 | 08:06 PM
t-von's Avatar
Rotor Head Extreme
Search the 2nd gen parts section to find a used one for around $50.00. Mine doesn't work either. I just premix 1oz of 2cyl oil to every 1 gallon of gas on my S5 vert.
Old May 10, 2006 | 11:35 AM
SureShot's Avatar
Seduced by the DARK SIDE
I saw one on e-bay this morning.
Old May 10, 2006 | 02:34 PM
How hard are these to install? Time and labor.
Old May 10, 2006 | 03:42 PM
Kim's Avatar
Kim
OBEY YOUR MAZDA
If you reuse the oilpipes, replacing the OMP itself should not be more than half an hour.
Old May 10, 2006 | 07:53 PM
Nice Thanks, If it doesnt end up being the oil metering pump, what else would cause my car to sputter and buck? I mean my car has less than 80k original miles its an N/A and its never been ran without oil or coolent.
Old May 11, 2006 | 07:02 AM
SureShot's Avatar
The OMP will just put you in default mode (limp home mode).
Intermittant mis-fires are usually something else.
My first guess is your TPS is just starting to wear out.
A bad spot in the sensor value at part throttle will confuse the ECU & give intermittant fuel cuts.
Old May 12, 2006 | 03:00 AM
t-von's Avatar
Rotor Head Extreme
My S5 vert isn't responding this way. When I rebuilt my engine, I also replaced all the OMP lines. With over 3k on the rebuild, the lines still haven't filled all the way so I've been premixing. Why wouldn't my ecu recognize this fault and kick into limp home mode? I'm starting to think this is what killed my engine in the first place even though my housings were still in great shape.
Old May 17, 2006 | 09:38 AM
SureShot's Avatar
Good show - catching the problem & pre-mixing.
The ECU sees MOP actuator continuity and position, but It can't see blocked oil supply line.
If the front cover was installed with sealant, it's easy to accidently block the oil passage hole to the MOP.
Old May 17, 2006 | 05:48 PM
t-von's Avatar
Rotor Head Extreme
Well this is exactly why I dislike the upgregaded braided steel OMP lines. You can't see anything.
I didn't use sealant, just the gasket. I also made sure the hole in the front cover was free of clogging. I believe the OMP on my 20b is the same, I may just try to use that one and see if it works.
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 31, 2015 07:49 PM
