Sponsored by: CARiD
Finding TDC on 12A
Old Apr 21, 2006 | 04:32 AM
odavemon's Avatar
Finding TDC on 12A
Whats a sure fire way to find TDC without using rhe mark in the eccentric pully ?This is a 12A with the engine in the car.
Old Apr 21, 2006 | 05:54 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
I no this may sound far fetched but,
Take a small phillips screw driver and remove the bottom spark plug , insert the driver carefully into the hole, and use a wrentch to turn the motor, the driver will eather raise out of the hole or go in as you turn the motor, when the driver stops moving in or out when turned a very small amount then that is your TDC.
As long as you dont turn the motor over too fast or keep turning the motor if the driver is raising out of the hole then you will not hurt anything.
This is how you can do it on all rotarys
Old Apr 21, 2006 | 07:29 AM
C. Ludwig's Avatar
www.lms-efi.com
http://www.teamfc3s.org/info/article...fying.html#TDC
Old Apr 21, 2006 | 09:20 AM
Siraniko's Avatar
RX for fun
here ya go.
https://www.rx7club.com/1st-gen-archive-71/ignition-main-pully-timing-525909/
Old Apr 21, 2006 | 09:30 AM
Rotaryhaven's Avatar
Total Rotary Domination!
Originally Posted by wackyracer
Damn, you are good!
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
The1Sun
Sep 14, 2015 06:13 PM
K4B00SS
1st Gen General Discussion
Sep 3, 2015 08:13 PM
