steering angle...
Old Apr 10, 2006 | 02:01 PM
mikemizzle's Avatar
steering angle...
I have an 81 rx7 and I wanna drift it, I'm doing the rack and pinion swap and gc coil overs with camber plates and 4to5 lug plates for the wheels but what can I do about extra steering angle?
Old Apr 10, 2006 | 04:15 PM
twilight slide's Avatar
That looks broken
some FC guys use washers where the tie rod goes into the rack for extra angle. . . you can find some info searching or on http://www.fc3spro.com/TECH/DRIFT/dori.html.
Old Apr 10, 2006 | 04:31 PM
B_Rock's Avatar
it's always broken...
I'd say to go for the spindle modification instead. I am researching doing the same thing to my FD. Just be carful to keep the tie rod in the same position vertically in relation to the control arm to avoid bumpsteer.
Old Apr 10, 2006 | 09:03 PM
eyecandy's Avatar
What kind of rack and pinion are you using?
The easist and safest option is one of the SuperNow! kits, they also offer bumpsteer adjustment for lowered vehicles.
Old Apr 11, 2006 | 12:06 PM
mikemizzle's Avatar
I'm buying the rack conversion kit from cp racing...
what is "SuperNow!"?
where does this part in pic go?what is it?
Old Apr 11, 2006 | 12:08 PM
mikemizzle's Avatar
what spindle mod?
Old Apr 11, 2006 | 12:42 PM
The Griffin's Avatar
Burning up Time
Check the "good guy/bad guy section" of this forum and all the other forums for that matter on CP racing.You are going do need some luck on your side sending out money.
Old Apr 11, 2006 | 12:52 PM
ptrhahn's Avatar
I prefer the SuperLater! kit, because it gives me extra time to set up for a corner.
Old Apr 12, 2006 | 01:23 PM
mikemizzle's Avatar
where do you find these kits? what are they? and who makes them?
Old Apr 12, 2006 | 01:26 PM
mikemizzle's Avatar
if cp racing is shady do you guys know where to get the stuff they have somewhere elis?
like the fender flares and the 4to5 lug conversion,
Old Apr 12, 2006 | 04:04 PM
jgrewe's Avatar
GET OFF MY LAWN
I want to know when somebody goes all out and installs a sprintcar front axle in one of these cars. Its the only way to get your front wheels totally sideways, that's why they use a straight axle.
As for the FB steering, have some steering arms made shorter and you will get more 'turn'(at the wheel) out of the rack travel.
KeloidJonesJr.'s Avatar
strictly business
Tie rods, camber, adjust toe, etc.. Fender flares do nothing, it's just for show.
Old Apr 12, 2006 | 07:41 PM
eyecandy's Avatar
Hmmm I am not firmilar with the CP Racing kit. what rack are they using?
SuperNow! is a Japanese coming specializing in performace products for many vehicles, specificly the FC and FD. The kit consists of a bolt on spacer for the tie rod (gives more steering angle) and new tie rod ends which allow bumpsteer adjustment. The FC gets approx 7-8 degrees more steering angle and the FDs get approx 5 degrees more angle.
These kits are used by many PRO and novice racers both in the USA and Japan, some notables are Tony Angelo (both FC and FD) and Calvin Wan.
RyanFox
Sep 18, 2015 09:09 PM
