power dropoff before redline?
Old Feb 9, 2002 | 03:19 PM
HuggyBear's Avatar
im noticing that around 6800-7000rpm im getting a power dropoff. is there some sort of rev limiter or fuel cutoff in my car causing this? any ideas?
car:
'90 GXL
k&n filter + air scoop shooting air into stock airbox
headers
no cats
cherry bombs
switch to disable fuel pressure regulator
this has been happening since i got the car
Old Feb 9, 2002 | 03:33 PM
Erik's Avatar
Best of both worlds
could be some dirty fuel injectors...or maybe you're ports aren't opening like they should...
Old Feb 9, 2002 | 03:37 PM
HuggyBear's Avatar
the engine pulls strong up until then, and i recently had my ports cleaned. also, with the fuel pressure regulator disabled, im getting the max fuel pressure so i should be getting all the fuel i need.
thanks for the thoughts on it though.
Old Feb 9, 2002 | 04:27 PM
SaabGuy's Avatar
How did you disable your fuel regulator? What PSI are you pushing to the rail?
Old Feb 9, 2002 | 06:32 PM
HuggyBear's Avatar
basically the system is prevented from shunting fuel back to the tank now, so its pushing the max pressure at the flick of a switch. i believe for a 90n/a its around 33psi. could be wrong though.
still looking for help with the ore-redline power loss....
Old Feb 9, 2002 | 06:40 PM
Scott 89t2's Avatar
SOLD THE RX-7!
umm where is the switch?... are you cutting off the vac to the fpr? or cuting off the return line so 100% pressure goes to the injectors? I really hope your not cutting off the return line, but I doubt it would run that way anyways as you'd have about 90psi
Old Feb 9, 2002 | 07:06 PM
HuggyBear's Avatar
the mod was done by a friend of mine. its set up with solenoid so i can flip a switch in the car while im driving to increae the pressure. i know im not running 90 psi though.... only about 30-35 or so.
Old Feb 9, 2002 | 08:26 PM
Scott 89t2's Avatar
SOLD THE RX-7!
does it die off with the sitch in both places? or just while on or off?
Old Feb 9, 2002 | 11:57 PM
HuggyBear's Avatar
on or off it still dies. even before this mod was done.
even before headers were put on.
Old Feb 10, 2002 | 12:24 AM
mazdaspeed7's Avatar
mad scientist
Check your timing, and clean your injectors.
Old Feb 10, 2002 | 12:33 AM
Angel Guard Racing Team's Avatar
It sounds like it's getting lean on the secondary injectors. Have them calibrated and cleaned.
Old Feb 10, 2002 | 12:58 AM
von's Avatar
von
Angel Gaurd
Hey Angel Gaurd... My car spits out droplets of gas when I start the car when cold. It goes away after it warms up. DO u know if its my injectors.. If so why would they clear up after warm. Mabey my tps is misadjusted??? NO.. Anyone.
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
