My V-Band is leaking
Old Mar 23, 2006 | 07:59 PM
Half Jap Boost Junky's Avatar
240RWHP 270TRQ @ 0.9Bar
Ok, seems like a simple problem, I hope there is a simple solution.
When I got my car back from the shop, the V-Band was leaking under the hood. I tightened it up the other day and it looked like the leak was sealed (I couldn't see anymore exaust rising up). Today I went out to start the car, and when I did, it looked like it was leaking again, but after the pipe warmed up a bit, I couldn't see it anymore. I also understand that just because I can't see it at the moment doesn't mean that there might not still be a leak.
Is there anything that I can use to try and for a better seal between the exaust housing and the downpipe? Or am I just going to have to live with it or get a new one?
-Kenji
Old Mar 23, 2006 | 08:06 PM
moehler's Avatar
This stuff worked wonders for me...
https://www.rx7club.com/single-turbo-rx-7s-23/v-band-flange-gasket-467421/
Old Mar 23, 2006 | 08:18 PM
GOTBANNED?'s Avatar
Boost Addict
I herd some poeple use Exhaust cement and it seal it up very tight.
Old Mar 23, 2006 | 08:35 PM
Thanks for the info guys, the turbo shop that welded up the V-Band said the same thing about the exhaust cement. Can I just get that at Canadian Tire? What exactly is it? Will it be hard to remove if I ever need to separate the DP and the Turbo?
moehler, I will definetly keep that stuff in mind. Did you trace the flange size with the turbo still in the engine bay or did you have to take it out?
-Kenji
Old Mar 23, 2006 | 08:43 PM
moehler's Avatar
-Kenji
I was able to measure the DP V-Band width with a compass, then I made the O ring from that measurement. I got a 2"x1.5" oval from those guys for $20 shipped. They said they have scrap ovals all the time for cheap so ask them.
My turo blew a month ago and when I removed it, the gasket didn't even look burnt after 2k miles. It's good stuff.
Old Mar 24, 2006 | 07:34 PM
Old Slow Coach's Avatar
Front Range Express
You damn right! LOL!
Old Mar 25, 2006 | 10:50 PM
BoOsTin FD's Avatar
Powered by** Rotary
What is this exhaust cement?? Will i be able to remove dp later if i need to?
I think i have a leak there as well and it keeps coming inside the car....
Old Mar 28, 2006 | 09:06 AM
rx7will's Avatar
I have used the exhaust paste/cement before and it does work. Its just a paste that you smear on the gasket or flanges. It like rtv for exhaust gaskets. You will be able to remove the components. Its not really "cement". This still will be the cheapest and easiet fix to try first.
Old Mar 28, 2006 | 01:33 PM
BoOsTin FD's Avatar
Powered by** Rotary
Where do you get it? Got a name?
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
