Fuel system questions
Old Mar 20, 2006 | 09:28 AM
1QK7's Avatar
My setup is as follows
Apexi Rx6
Greddy 2 row
Power Fc
Fluidyne radiator
non resonaited mid-pipe
Greddy SP exhaust
greddy Profec B Spec 2 controller
hks twin power ignition
unorthodox pulleys
Ive almost completed the installation of the above listed mods on my single turbo conversion. The only thing Ive yet to install is the fuel syestem. Im shooting for 400hp under 15lbs of boost. Ive been told send the secondarys to RC and get them bored out. It would defently be the easist. But then alot of people tell me 1300's fail and they suck. What fuel system should I get to keep the duty cycle under 85%. Just cant decide. Thanks
Old Mar 20, 2006 | 09:43 AM
charlies7's Avatar
3rd rotors a charm
kgparts 1680's cc and there rail. Then youll need to get a aftermarket fpr. Thats the setup im running and im keeping the stock 550's. You could never has enough fuel. Ive also heard bad things about bored out injectors and ive also heard good. I believe its all about the condition and mileage on the injector that determines if it is going to fail or not.
Old Mar 20, 2006 | 06:16 PM
Heisenberg's Avatar
Civilization is crumblin
There is a group buy going on for KGParts on the fuel system you probably want to run.
https://www.rx7club.com/group-buy-center-69/fuel-system-511435/
Old Mar 20, 2006 | 06:26 PM
rynberg's Avatar
Since you are not emissions legal anymore anyway, I would definitely go with an aftermarket rail with the 1600s.
Old Mar 20, 2006 | 07:08 PM
vel525's Avatar
Woo Hoo, It Runs!!
Agree with the above recommendations. I would get an aftermarket secondary rail, 1600s, FPR, and upgraded fuel pump. If it were me, I would upgrade lines to stainless while you're at it.
Old Mar 20, 2006 | 08:58 PM
1QK7's Avatar
So based on your guys advice about not doing the 1300's. I called rotary extreme about there extreme fuel rail system. They are running sale right now on there system.It includes
1680 cc/min injectors x 2,
fuel rail x 1,
SARD FPR x 1,
fuel pressure gauge,
and all the lines and fittings
electrical
on sale for $525.00
I got this isetup shoutl be here by the end of the week. Anyone look for a secodary setup give chuch a call at rotary extreme. Awesome guy and good price.I will post once I get it about the install.
Old Mar 20, 2006 | 09:44 PM
charlies7's Avatar
3rd rotors a charm
nice but correct me if im wrong isnt 400whp at 15psi a lil far fetched for a rx6
Old Mar 20, 2006 | 10:04 PM
rynberg's Avatar
Yes it is, for a stock ported motor. And also far-fetched on our ****-water 91 octane, at least if you want a safe tune.
Old Mar 20, 2006 | 11:02 PM
1QK7's Avatar
not sure why some people think 400 hp at 15 psi not possible with rx6 ive seen numerous dyno charts between 390rwhp and 420rwhp at 13-14psi here is a dyno chart @18 psi.
http://dyno.zeroglabs.com/graph.php?...1&SUBMIT=GRAPH
Old Mar 21, 2006 | 03:08 AM
Rotary4tw's Avatar
For the win...
Good Luck
I don't think you will make much over 400+ hp at 15psi. Probably more like a quick spooling 375. (Which is still very respectable)
Perhaps you have seen numbers from an Rx-6B?
I'm going to be installing the same turbo as well, on a new engine with large ports. From everything I have read, 18PSI is quite a bit for these turbos, and things may start to get really hot that high, and also move out of the turbos efficiency range. Hopefully your two row will handle the intake temps.
I think Rynbergs comment about only having 91 is very important too, I would be afraid to run 15psi on 91! Have you considered water injection?
Good luck, and make sure to post your results!
-Rotary4tw
Old Mar 21, 2006 | 07:31 AM
For what it's worth, my 1300cc RC Engineering secondaries have never given me any problems.
As stated above, if you have the 'regular' rx-6, I doubt you'll make it to 400 at 15. The hotside on that turbo is very tiny, and I have driven three cars now with that turbo at about 15 psi and there is no way in hell it felt like 400 to the ground. Actually, it kinda reminded me of stock seq twins---responsive, but ran out of steam towards redline.
Old Mar 21, 2006 | 07:09 PM
rynberg's Avatar
We didn't say it wasn't possible. We said that on stock ports and 91 octane, it would not be feasible with a SAFE tune.
Old Mar 21, 2006 | 09:57 PM
1QK7's Avatar
400 hp is hopeful but not sure of the reality of it. I will be happy anywhere in the upper 350's or so. I got this kit becasue I wanted a fun drivable car that would'nt push my mazduh reman to the edge. I will post some numbers when I get them. Thanks again for all the help guys.
Old Mar 25, 2006 | 09:42 PM
bobybeach's Avatar
what about fuel lines? can standard lines support the fuel requirment for 1600cc secondaries?
Old Mar 25, 2006 | 10:10 PM
the_glass_man's Avatar
Will u do me a kindness?
Cheuk in Seoul made over 400 to the wheels with his RX6 a long time ago. The norm is usually 360-380 rwhp at that boost level.
https://www.rx7club.com/showthread.p...33#post1720533
Old Mar 25, 2006 | 11:32 PM
yes.
82streetracer
Aug 23, 2015 09:28 AM
