View Poll Results: Nitrous Oxide Injection On A Rotary Engine
Yes, "Wet"
37
52.11%
Yes, "Dry"
7.04%
No, Not At All
20
28.17%
Only "Wet" On Low Mile Engines
9.86%
Only "Dry" on Low Mile Engines
1.41%
Other (Just In Case I Forgot An Option )
1.41%
Voters: 71. You may not vote on this poll
Nitrous Oxide Injection...
Old Feb 8, 2002 | 06:21 AM
RotorMotorDriver's Avatar
Seven Is Coming
So I was wondering, what is the mass consensus reguarding nitrous injection on a rotary engine...Is it good or bad?
Old Feb 8, 2002 | 07:18 AM
brownmound's Avatar
Anytime baby!
"NOSSSSSSSSSS!"
(boom)
F&F. Ha.
Right on-
Old Feb 8, 2002 | 08:40 AM
David88vert's Avatar
r71's daddy
I have it on my GSL-SE. No problems. 100 shot wet.
Old Feb 8, 2002 | 08:55 AM
Tigger09's Avatar
What is the different between wet and dry?
Old Feb 8, 2002 | 12:46 PM
mar3's Avatar
Administrator
A "dry" system is for fuel injected systems only. I suppose if you just used a 25 shot of juice and your carb was already jetted rich, you'd be OK with a dry system but I sure wouldn't bother with NOS if I was only going to use just the 25 HP jet. The dry system only has a solenoid for nitrous injection. The box controlling a dry system piggybacks on the car's ECU so it can tell it to increase the duty cycle of the gas injectors already on the engine to supply the extra fuel necessary when the sytem is working. A "wet" system is much simpler. It has two solenoids. One to inject nitrous and one to inject extra fuel. They both come on at the same time and that is determined by you with a push of a button or, better, a micro-switch cobbled onto the carburetor to click "on" only at WOT. If you're carbureted and want more than just 25 horseys from your $450 NOS system, you have to use a wet system.
Old Feb 8, 2002 | 10:30 PM
peejay's Avatar
Old [Sch|F]ool
Dry systems worry me even for the proper application.... always go for a wet, preferably a plate system. Don't think they make a plate system for RX-7s, though, they only make them for normal Holley pattern carbs.
- pj (nitrous = path to the Dark Side )
Old Feb 10, 2002 | 09:25 AM
JIMMY54's Avatar
GSL-SE PRO
David88vert
What are the details on your nos kit, what hp rating? or part number if possible? I have a se and I'm thinking about nos. what are the do's and don'ts for example? How many times can it be used while driving, side effects on the engine (eg overheating?).
Thanks in advance
Old Feb 10, 2002 | 09:48 AM
r71's daddy
Quick overview:
I have a NOS Sniper system for a V8. I use the 100 n2o fitting and the 125 fuel fitting. Retard timing 2 degrees for every 50 shot. That's 4 degrees on the 100 shot. Never use it unless you are floored. Use it only when "necessary". I have had zero problems with the system.
Old Feb 11, 2002 | 07:12 AM
Seven Is Coming
Weird...Only Wet and Not At All are exactly the same....hmmmm
~T.J.
Old Feb 11, 2002 | 08:14 AM
JIMMY54's Avatar
GSL-SE PRO
I've been looking at the dry system, 50 shot. Looks easy to install, and is about $499. There was a rx7 with a similiar kit installed on a 2nd gen.
Old Feb 11, 2002 | 09:20 AM
r71's daddy
You should be polling people that actually have run N2O, not people who have not had experiences with it personally. No offense, but the thing "my friend has it", is not personal experience. There are a lot of rumors that float around that get said as though they were fact.
Old Feb 11, 2002 | 05:24 PM
yayarx7's Avatar
Are you Nucking Futs?
Ditto!
Old Feb 11, 2002 | 09:35 PM
Seven Is Coming
I just wanted to know what the mass consensus was on the subject...Im not looking for advise on what to buy because i dont plan on it, i just wanted to know what everyone thought so its no big deal on who answers...
Old Feb 14, 2002 | 10:14 PM
mar3's Avatar
Administrator
I was thinking of just going 75 to be safe until I saw David88vert's setup. Is the GSL-SE basically stock or was it rebuilt with nitrous in mind? If it's stock, I'm going 100, baby!! Gimme my refund, Dubya!!
Old Feb 15, 2002 | 07:47 AM
r71's daddy
It was rebuilt first with large street ports. I would suggest on a stock port, non-rebuilt motor to start with a 50 shot wet first.
Old Feb 15, 2002 | 05:40 PM
V8kilr's Avatar
my buddy threw nos on his mint 91 rx7,NA,it was bad ***,but didnt last no more then one day,now its just ***.only had 60,000 original miles on it,damn shame
Old Jul 3, 2002 | 05:42 PM
jeremy's Avatar
male stripper
somebody warn the newbie of dragging up old threads. i better see this **** cleaned up when i get back.
Old Jul 3, 2002 | 08:44 PM
crafoo's Avatar
no exp with nitrous on rotaries, but i've ran a Nitrous Express kit on my mustang - wet kit with misc parts from venom and Holley/NOS as well. it's fun but not as cheap as you first think to do it right and safe.
wet kits are the way to go.
use a WOT switch, fuel pressure limit switch - also, use an rpm window switch if u've got the $$$.
bottle warmer highly recommended, and a line purge system.
all told you'll be looking at $1100-1200 for a proper system. might as well just put it into a 13b TII swap.
Old Jul 3, 2002 | 10:15 PM
mar3's Avatar
Administrator
Do it eBay (except for the fuel and nitrous solenoids...absolutely get those new...) style and you'll be a playah at a quarter of that guesstimate...ya just gotta be patient. It's how I'm doing it. Too bad my '80 got wiped out.
Old Jul 4, 2002 | 05:07 AM
Manntis's Avatar
add to cart
'good' or 'bad' in what sense? Good in the speed performance sense, short term, bad in the engine wear life sense, long term
Old Jul 4, 2002 | 08:38 AM
crafoo's Avatar
hey, ebay, that's a good idea mar3. what's up with your 80 rx7? is an insurance company trying to rip u off? when I got t-boned in my 83 (by a jacked up jeep cj5 with steel I-beam bumper) they were going to give me $500! xlnt shape, custom wheels, blah blah... they ended up giving me $0 because they pulled some school zone BS and said I was partially at fault. ah well. I REALLY wish i had gotten a lawyer and not said $&^% to the insurance company myself.
btw, rx7s hold up pretty well in a side collision.
Old Jul 10, 2002 | 02:59 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
holley has/or did have a kit for carbed RX7s I saw it in a catalog.
Old Dec 7, 2002 | 01:31 AM
Seven Is Coming
Jeremy said it best a while ago...This thread is OLD!!!
~T.J.
Old Dec 7, 2002 | 12:29 PM
Felix Wankel's Avatar
Super Newbie
Its from people voting and not posting anything. Voting should be turned off after a certain period of time or something....
Old Dec 11, 2002 | 01:22 PM
I had a dry NOS setup on my 91 n/a with only a fifty shot, couldn't get it to work and ended up breaking an apex seal. After the engine rebuild and porting and putting a holley 600 with a wet NOS kit and pushing a 100 shot it was working but was intermitting sometimes. I think that was due to the higher compression rotors in the 89-91 n/a's. But man, with a street port and a 100 shot the car was flying when it was working!
