need help with rebuild of nikki asap please
Old Feb 11, 2006 | 04:36 PM
blwfly's Avatar
kiwi from downunder..
ok i brought a rebuild kit
the pictures are self explanitry what do i doo what are those holes for can they be covered up with my new gaskets should i use both or just 1
Attached Thumbnails need help with rebuild of nikki asap please-img_0005.jpg   need help with rebuild of nikki asap please-img_0006.jpg
Old Feb 11, 2006 | 04:41 PM
blwfly's Avatar
i see there on the manifold so are they from the oil cycle to the nikki if so i could just premix and later remove the omp seing it would be opsalete
Old Feb 11, 2006 | 05:16 PM
blwfly's Avatar
bump
Old Feb 11, 2006 | 06:00 PM
vipernicus42's Avatar
Rotoholic Moderookie
Use your old gasket or punch holes in the new one. The carb rebuild kit came with very generic gaskets instead of quality specific ones. Probably because the position of those holes changed over the years and they were too lazy to make up many gaskets, so they just gave you blanks to use.
Good carb rebuild kits should come with the right gaskets but they don't always.
Worst case scenario, I've used a thin layer of red silicon before instead of a gasket, make sure you don't block the holes!
And don't bump your messages, especially less than 24 hrs apart. By bumping, you push someone else's message down, which isn't very nice. You can't expect immediate responses. Some of us only come on once per day. So post your message, wait 24 hrs, and if it falls right off the main page, THEN you can try bumping. And when you bump, try to ask more specific questions or provide more info.
Jon
Old Feb 11, 2006 | 06:27 PM
blwfly's Avatar
ok sorry bout that ill stick tot he 24hrs gap before i do it
thanks for ya help lucky i asked
im gonna try find me apropiate punch
what are the holes for?? as ive removed a lot of unsessarythings and goin mech secondays
7upra
Mar 25, 2018 11:32 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
