Strange Clicking Noise!
Old Jan 30, 2002 | 01:24 PM
HoNdAh8rRx7LuVr's Avatar
Nissan ownz me
Angry Strange Clicking Noise!
wsup folks? heres my problem,my car wont start,and im the the process of doin the atf trick. In the last few days I think I killed my starter while trying all the various start-up tricks. When i turn the key on the volts go to 12v, when I go to start it the power drops to well below 10v and a lil' bit higher than 8v. My starter I'm assuming thats what it is , is just clicking now,and it wont even crank anymore. I just put a new 550 c.c.amps battery in it 2 days ago. When I first put it in it cranked perfectly and almost kicked over,.....now it just clicks .
Old Jan 30, 2002 | 01:26 PM
Felix Wankel's Avatar
Super Newbie
Tighten the battery cables.
Old Jan 30, 2002 | 01:28 PM
Nissan ownz me
R U SERIOUS?!?! Wow do I feel dumb
Old Jan 30, 2002 | 01:29 PM
Super Newbie
If it gets a **** connection, the current can't flow well enough to turn the starter over.
Old Jan 30, 2002 | 01:33 PM
Nissan ownz me
Thanx I'll go fix that when it stops raining here!
Old Jan 30, 2002 | 01:36 PM
Nissan ownz me
Felix I know you've been reading my other posts that I put up under my other name luvmyrx7420. Do think its fucked and i should just get a new enine??? Or keep tryin' until i know for sure it's gone???
Old Jan 31, 2002 | 08:40 AM
Nissan ownz me
Question WHAT NO HELP?!?!?
ANYONE ELSE HAVE ANY FEED BACK ON THIS????
Old Jan 31, 2002 | 08:52 AM
ralph f cooke's Avatar
I know I'm probably asking a stupid question, but is your battery fully charged?, not too old ? The reason I ask is that I had a similar problem recently after I fitted a very large electric fan to my TII. The sensor is wired so that the fan will come on at any time the rad is hot enough. one time I was drivin through town and stopped to do some shopping. When I came back out of the shop about 25 mins later all I got was a click from the starter. It turned out that the fan motor was drawing around 16 amps and as my battery was real old it was enough to take the voltage down to the point where there wasn't enough to engage the starter
Old Jan 31, 2002 | 08:55 AM
HAILERS's Avatar
HAILERS
New battery needs a charge. Your car has not started since who knows when and you've been trying to start it without recharging the battery. The ECU is chomping power while you have the key on, even if the car isn't being rotated. That plus the battery grounds. Two days of trying to start a car will definetly run the batt down.
Old Jan 31, 2002 | 09:26 AM
Nissan ownz me
Talking THANX
THANX HAILERS & RALPH!! I'll have it recharged.
Old Jan 31, 2002 | 11:31 AM
tIIforever's Avatar
terminally boosted
if the recharging doesn't work try a new solenoid thats what happened on my suburban it would just click and wouldn't turn over until i put a new solenoid in it.
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
