Leaking primary injectors
Old Jan 30, 2002 | 12:26 PM
GEB's Avatar
GEB
Question Leaking primary injectors
Subject line says it...
93 FD. Stock 550 primaries
Whould I be best served by purchasing new or having them fixed?
Thanks in advance
GEB
Old Jan 30, 2002 | 12:29 PM
BlackR1's Avatar
Meesto Spakaro
get new ones ASAP. My engine died due to leaky injectors causing a lean condition. One ping is all it takes...
Old Jan 30, 2002 | 02:11 PM
kevinmfaust's Avatar
There is nothing wrong with rebuilding them. A rebuild co. will replace all the seals inside, give you all new O-rings and check its performance to see if it is working properly. I had mine rebuilt and they got them to flow with in 2% of each other. If you can give them a week to get it and ship it back it is worth it. Like $35.00 per injector. Bargain.
Kevin
Old Jan 30, 2002 | 02:58 PM
level7's Avatar
Search Button Advocate
question: does your car reek of gas or any other fumes on startup?
Old Jan 30, 2002 | 05:08 PM
GEB's Avatar
GEB
It always reeked real bad of gas when I would it turn it off after parking
in my garage. I guess the enclosed space in my garage made the smell
much more obvious.
Don Marvel had my UIM off to replace my pulsation dampner, which was
leaking pretty bad. After he replaced the PD he repressurized the
system and the primaries started squirting too.
Major Bummer....oh well. It could have been a lot worse if it hadn't
been caught.
Old Jan 31, 2002 | 07:23 PM
accurizing's Avatar
Kevin
Who did you send it to that charged $35 an injector?
Old Jan 31, 2002 | 09:50 PM
FD Seeker's Avatar
Rotary Optimist
Those bastard little pieces cost me a ton of dough... they were like $300 each and the labor wasn't cheap either. No one told me they could be reconditioned! I suppose my shop wouldn't have recommended that anyway.
Old Feb 1, 2002 | 04:57 PM
silver93's Avatar
send them out to RC Engineering. They will take care of it and match and map them as well. Much cheaper than buying new ones.
You do have to get new Orings from mazda, though.
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
gabescanlon
Sep 5, 2015 12:04 AM
FührerTüner
Sep 4, 2015 01:41 PM
