oil pressure
Old Jan 29, 2002 | 08:18 PM
zigger1's Avatar
oil pressure
what is teh proper oil pressure reading on a 87' rx-7. Another question is what does teh oil pressure realte to. I though rx-7's just mixed teh oil with the gas like a 2 cycle. How does teh oiling system work?
Old Jan 29, 2002 | 08:32 PM
NZConvertible's Avatar
I'm a boost creep...
Dude, learn to type!
The oiling system works exactly the same and does exactly the same job as a piston engine: it lubricates the moving bits! It also handles a bit of the cooling which is why they have an oil cooler.
Oil pressure for an 88 should be 64-78psi @ 3000rpm when warm according to the FSM. 87 should be about the same.
Old Jan 29, 2002 | 08:57 PM
HAILERS's Avatar
HAILERS
Naw. 87's are not the same. They're better than the other years. humor.
Old Jan 29, 2002 | 09:12 PM
zigger1's Avatar
well I am running about 60 at 3000 is that ok?
Old Jan 29, 2002 | 09:21 PM
Greys 10th's Avatar
60 is fine @ 3000rpm
Old Jan 29, 2002 | 09:38 PM
Wankel7's Avatar
Haven't we ALL heard this
But the question is how do you read 60 psi at 3000 RPM? Is that with a stock gauge, aftermarket gauge, or mech. oil pressure tester?
James
Old Jan 29, 2002 | 09:57 PM
The stock gauge is poo but if it's always above 60psi on the gauge it's probably OK.
And an aftermarket gauge is just a mechanical oil pressure tester! Unless you get an electrical one of course.
You either replace the oil pressure idiot light sender with the gauge sender or put a T in so you can have both.
Old Jan 30, 2002 | 08:38 AM
HAILERS's Avatar
HAILERS
If you read the factory service manual where they check out the oil pressure and give you the specs, that they show the mechanic bypassing the factory sending unit and using a mechanical gauge, for accuracy. Says a lot about the electrical unit in the car.
Old Jan 30, 2002 | 10:26 AM
FDxc's Avatar
my motor oil POPPED for some reason and it spilled all over my radiator.. but i/ my mechanic cant find where it popped!!! It used to leak only a little bit .. and never popped like this when it was idling.. Now everything seems to be normal, like it NEVER happened before! why is my car acting up?!!! could it be the pressure ? its normal now though.. =\
Old Jan 30, 2002 | 03:18 PM
Wankel7's Avatar
Huh, popped but it is working fine now. Maybe blew some out of the rebreather line that goes into the top of the oil fill. But a rapid spewing of oil sometimes comes from a burst oil cooler line. You find those on the driver side frame rail. One goes into the front of the engine and the other runs along the frame rail to the back of the engine. Basicly below the oil filter stand
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
