Wastegate Porting
Old Jan 28, 2002 | 10:32 AM
iluvrx7z's Avatar
Wastegate Porting
Hey guys I have been doing some research on porting the wastegate on a series 4 turbo. I am looking for some before and after pics so I can be sure of what I am doing. Or at least tips from someone who has personally done it. How much can I port out of it? I don't wanna kill my turbo!!! Thanks in advance!
Dan
Old Jan 28, 2002 | 10:56 AM
Erik's Avatar
Best of both worlds
there used to be some pics on the k2rd site (before and after)...i know i've seen what you're looking for...someone on here must have the address...
Old Jan 28, 2002 | 02:39 PM
NZConvertible's Avatar
I'm a boost creep...
I think all the FC info has been removed from the K2RD site, but I have all the pics of their wastegate porting saved. I can email them if you haven't got hold of them yet.
Old Jan 28, 2002 | 03:34 PM
86Rx7GXL's Avatar
Hey Jason, Can you send those pics to me RotarHead13BT@aol.com
Old Jan 28, 2002 | 03:36 PM
No probs, it'll be a bit later, they're on a different computer.
Old Jan 28, 2002 | 05:05 PM
dave007's Avatar
We got this...
Pics of Wastegate porting
Hey Jason,
Please send me a copy of the Wastegate porting pics too. - Davidlev14@aol.com
-Thanks
Old Jan 28, 2002 | 07:00 PM
iluvrx7z's Avatar
Hey, No I have not found it yet...I have been trying for quite some time now. If you don't mind emailing it to me I'd appreciate it a lot! Thank you in advance!
Send to: uconnhusky78@hotmail.com
Thank you!
Dan
Old Jun 14, 2003 | 01:33 AM
Jaared's Avatar
Ahhhhhhhh hhh....
old thread. i need the pics or a link to the info for doing a s4.
is it that bad.
look at my mods in sig and tell me how bad boost creep will be with ported s4 turbo.
Old Jun 14, 2003 | 05:40 AM
joelu's Avatar
how bout these
Old Jun 14, 2003 | 09:18 AM
RylAssassin's Avatar
It really doesent have to be that specific, i mean keep in mind that all you have to do is port it not more than the flapper door, that way no exaust gases bypass at all. But you really want to get it as large as possible to cure any creep you might have.
Old Jun 14, 2003 | 03:55 PM
Bambam7's Avatar
I came, I saw, I boosted.
You don't need pics...
Just make the hole bigger!!!
You CAN go larger than the flapper door. You shouldn't unless you have a real problem with boost creep though. I had to though.
As long as at least 80% of the hole is covered by the flapper, you shoudln't have a noticable difference in turbo spoolup time.
Also- angle the hole, smoothing out the back of the wastgate as well, just look at it as a flow of fluid, and look at the parts that would make the flow more turbulant... every bit counts.
Old Jun 14, 2003 | 10:09 PM
If you're going to port bigger than the stock flap then you should get a bigger flap fitted. This would be a simple job for a turbo shop. I would think any leakage of the wastegate would slow turbo response, and these these old turbos aren't that great in that department to start with...
Old Jun 14, 2003 | 11:27 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i agree, porting the gate larger than the flapper will increase spoolup times. boostmotorsport used an exhaust valve from a 4banger to replace his wastegate door, its much larger than the stock flapper
Shainiac
Jul 17, 2019 02:20 PM
Ian_D
Oct 14, 2015 12:31 PM
