Suspension Techniques Front Sway Bar.... Clunk when braking?
Old Jan 28, 2002 | 09:50 AM
vnova94's Avatar
Has anyone who has the Suspension Techniques front sway bar installed, experienced a clunk when braking hard? I just had the car at my mechanic, and he tightened everything up and thought the clunk was gone, but it's back again..... he suggested it was because of the brackets that are used? Anyone have experience with these sway bars?
Thanks,
Matt
Old Jan 28, 2002 | 11:10 AM
check your sway bar bushings to see that you didn't put them in backwards and check the control arm mounts for a loose bushing those bang like crazy under braking if their soft or improperly torqed down.
Old Jan 29, 2002 | 02:24 AM
Jerk_Racer's Avatar
Mine doesn't clunk. I wasn't aware that there was a wrong way to put the bushings in. I guess I got lucky.
jerk_racer@hotmail.com
Old Jan 29, 2002 | 10:00 AM
I found that out the hard way,you want the split to face the front. If you put it the other way the sway bar cuts its way through and the bar clunks around.It takes some time to happen.
Old Jan 29, 2002 | 08:40 PM
Jerk_Racer's Avatar
Thanks. I'll have to check that out next time I'm under there.
matty
Jan 18, 2020 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
