please help me tune my APEXI AVC-R !!!!!!!!!!!!!
Old May 18, 2001 | 02:48 PM
Alx7's Avatar
Unhappy please help me tune my APEXI AVC-R !!!!!!!!!!!!!
Hey guys ,,,
i recently purchased my AVC-R...from some guys that were selling it at a really good price...im trying to set my boost but can not get it to work....please help me...
on my ..
setting A.. im trying to run .60 bar... the highest it goes is .53.. which is like 8 psi..
setting B.. .80 bar... is not doing higher than .63 is like 10 psi..
guys that have the AVC-R should know what im talking about...
im not sure what my duty is supposed to be set to... so i think thats what the problem is..
so if you guys could help me out ...i'd appreciated...
im running the stock sequential set up...with this mods..
1. APEXI N1 exhaust ..
2. APEXI GTR SPEC. front mount intercooler.
3. APEXI POWER INTAKES.
4. APEXI AVC-R boost controller.
5. HKS downpipe.
please if you have any suggestions..let me know..
THX
ALX-7
Old May 18, 2001 | 04:10 PM
rxrotary2_7's Avatar
Talking
private message me and i will tell you everything you need to know.
Old May 18, 2001 | 07:32 PM
Alx7's Avatar
how can i private message u????
thx.
ALX-7
Old May 18, 2001 | 08:11 PM
just hit the button on my message above that looks like it says pm
***i know the pieces fit, i watched them fall apart*** tool
Old May 18, 2001 | 08:34 PM
Alx7's Avatar
how do i check when u send me stuff back????
Old May 18, 2001 | 11:39 PM
at the top of the forum it will show you the private mesages, it will say log in....and that is what you should do. first try that site that was posted for you to try. i am out of town, and it is hard for me to sit down for a period of time to get so into detail. try www.robrobinette.com 's site listed as a link a few replies up. that should keep you going for a day or 2 until i can sit down and type away.
Old May 19, 2001 | 09:23 AM
Alx7's Avatar
aight ill check it out...thx for the info guys...
ALX-7
Old Sep 21, 2001 | 09:48 PM
Sidestick's Avatar
AVC-R
Hey Alx, I just installed an AVC-R on my FD, & found that I'm having the same problem you had back in May. I searched in the archives & found your old post about it.
So, anyway did you get it fixed? If so how? Any help would be appreciated.
Thanks, Chris
Old Sep 21, 2001 | 10:20 PM
Alx7's Avatar
Red face
hey SideStick,
well i got my AVC-R to work finally,,,,it works really good.....
go to this webpage....
http://www.rx7turboturbo.com/robrobi..._r_install.htm
follow everystep..exactly as it says.....thats what i did....
this should be all...
it will work ...... now im havin alot of fun playin around with my settings...=)
good luck....
and let me know how everything goes for ya..
ALX-7
Old Sep 22, 2001 | 12:34 AM
Sidestick's Avatar
Hey Alx, thanks for the quick reply man! I actually used that same page to help with my install, so I either did something wrong or something isn't working. Let me ask you a coupla q's.
1.Where did you tap the line for the pressure sensor? I T'd mine from the same line for my boost gauge.
2. What did you do with the electrical connectors for the stock wastegate & precontrol solenoids? Did you disconnect them?
Thanks again, Chris.
BTW, what did you find that you had done wrong?
In the meantime, I'll look over that installation page again.
Old Sep 22, 2001 | 02:16 AM
Dreamin's Avatar
1) T-d off of another line going into manifold, not the boost gauge line... but I dont think this shouldn't matter
2) My electrical connectors are still plugged into the solenoids. But the solenoids are completely out of the boost control process (disconnected hoses).
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
