T4 turbo help?
Old Dec 3, 2005 | 08:58 PM
full-cruise's Avatar
D.I.L.U.S.I.
Arrow T4 turbo help?
Im looking for a T4 turbo so I can close this project up soon. I have a guy selling one and its a Garret TO4B with 3" intake, 2.5" compressor wheel, 2" discharge, 3" exhaust turbine, 4 bolt exhaust flange, and a 3" exhaust outlet. Turbo has a .80 A/R on the intake side and a .96 A/R on the exhaust side. OIL cooled only I believe will be used on a greddy cast manifold and a TiAL 40MM External Waistgate if I get it.
The motor is a S4 with ITO's street port with a lot of the other mods needed to push the boost but searching around on these forums the 60-1 seems to be the one to go with.
Would this turbo be to much for the motor?
The turbo is only oil cool, can I loop the coolant around back into the block without worries?
I dont know much about turbo's and any help or direction would be appreciated with this..
Old Dec 4, 2005 | 03:35 AM
4CN Air's Avatar
DETH TRP
you can either loop the coolant or block it off. The best way is to drill, tap, and plug the water ports, but rubber hose caps should do just fine.
Your specs don't give enough information about the turbo. Each wheel (compressor and turbine) have two measurements each. Doing more research before starting your project will make the process go much smoother. Here is a nice place to start: http://www.turbobygarrett.com/turbob...ch_center.html
Old Dec 4, 2005 | 09:28 AM
D.I.L.U.S.I.
i will get more info on the trims. thanks
Old Dec 4, 2005 | 12:02 PM
D.I.L.U.S.I.
The compressor is a 2.5" wheel at .80 a/r and the turbine is a 3" wheel at .96 a/r. it has a S trim
Old Dec 4, 2005 | 12:45 PM
4CN Air's Avatar
DETH TRP
exducer and inducer diameters of each wheel are needed. Well not for the turbine wheel, if it's an "S-trim"?
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
