Doing motormounts tomorrow, any useful tips
Old Oct 29, 2005 | 09:54 AM
Mindspin311's Avatar
Powered By Trochoids
Anything that could make this go smoother? I know there are going to be the toughest 14mm bolts Ive ever encountered. Where should I jack the engine up from?
Old Oct 29, 2005 | 10:42 AM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
if you can get get a engine hoist that would be even better and easier. but if you cant get one a guess a block of wodd and a jack will work. just try to jack it up from anywhere solid. not from the center of the oil pan!!
Old Oct 29, 2005 | 11:23 AM
patman's Avatar
Resident Know-it-All
you HAVE to use a hoist. doing it from the oil pan is a huge pain in the *** and a bad idea. even a comealong and a tree is ok.
the blots are actually relatively easy to take off, just make sure you only lift the engine a very little bit at first. lift it just enough to get the weight off, loosen all bolts, then lift it the rest of the way.
pat
Old Oct 29, 2005 | 12:42 PM
gxlspeeder's Avatar
Put a jack under the transmission. Worked for me just fine.
Old Oct 29, 2005 | 04:02 PM
eastcoastdrift's Avatar
Jacking the whole motor by the trans?? Sounds pretty dangerous to me. Cherry picker is best and the only way to do it riight like everyone said.
Old Oct 29, 2005 | 04:11 PM
dsmrx7's Avatar
I did it with a jack and a 2 x 4. (I was in a hurry. The engine hoist was being used on another car.)
Old Oct 29, 2005 | 05:01 PM
spot_skater's Avatar
The Cause of Death
I replaced the oil pan on my car last week, and it involved jacking the engine up with the mounts out, soooo.....
I had a lift when I did it, so I'll tell you what I did, then I'll talk about doing it without a lift (on the floor).
Alright, first get that bitch up in the air, then get a tranny jack or something that can raise up, and is strong enough to hold the trans and motor in the air. Put a block of wood in between the jack and wherever you're going to prop it up from, I used the bellhousing of the transmission (right BEHIND the oil pan, if you're looking from the front of the car). Put the piece of wood in place, then jack it up very slightly, just so you see it move a little bit. There are two bolts on the passenger side mount that go in through the oil pan. And another one to the right of those two bolts, then the one bolting the mount to the frame. Remove all of them. There should only be two bolts for the one on the driver's side (easy). Next raise the tranny jack a little bit at a time, until the mounts will slide right out. They should slide right out, rather easily, depending on how much you jacked up the transmission and motor. Installation is the reverse, make sure you put the two bolts that go into that mount on the pass side (through the pan into the motor) in first, cause things might get uneven when you put it back down. I learned that the hardway, had to take em out and do it again.
If you're not on a lift, get the car on jackstands high enough to slide under it. Get a jack with a piece of wood and slowly start to jack up the trans/engine a very little bit. Take all bolts out, and the 14mm nut on each mount. Get the trans/engine a little higher, slide them out. And do everything the rest of the way. Do not jack anything up by your oil pan, it will crush. Go from the transmission, it's strong enough.
Good Luck,
James
Old Oct 29, 2005 | 08:22 PM
slpin's Avatar
7th Heaven
put on the drive side mount first, then do the passenger side - because if you wiggle the 3 boltes that go tot he oil pan and the mount, it drops in VERY EASILY.
a jack as far up front as you can on the tranny is good...
Old Oct 29, 2005 | 08:40 PM
JJ01769's Avatar
Lovin The Spinnin Doritos
It took me about 10 minutes to do it. I just jacked it up on the oil pan. I hardly had to jack it up before I could slide them in.
Old Oct 29, 2005 | 09:25 PM
I thought there were only 2 bolts on each side? THe bottom and top of each mount. What is this talk of otherb bolts on the passenger side?
Old Oct 29, 2005 | 10:57 PM
JJ01769's Avatar
Two bolts on each mount. No idea what the other bolts could be...
Old Oct 29, 2005 | 11:08 PM
cprx7's Avatar
aka Underdog
Just do it. It's stupid simple. All you need is jack stands, floor jack with a good lift distance a piece of wood and hand tools. Driver side will give you some bloody nuckles but nothing too bad. Good luck.
Old Oct 30, 2005 | 04:04 PM
Done, Done and Done. Took me about 2 hours including having to go to a friends house and get a different jack and taking 15 mins to get the one top drivers side bolt on. ******* thing.
93FD510
Oct 1, 2015 02:00 PM
Rotafuzz
Sep 30, 2015 09:55 AM
