Help me name that turbo
Old Oct 26, 2005 | 11:14 PM
88t2romad's Avatar
(_8(|)
Hopefully pics can be enough. If needed, i can measure stuff on it.
It fits on stock s5 mani, thats all the info i can really provide.......now onto pics
BTW its forsale
<img src="http://i7.photobucket.com/albums/y265/t2romad/000_0053.jpg" alt="Image hosted by Photobucket.com">
Thanks guys.
Old Oct 26, 2005 | 11:59 PM
RETed's Avatar
If it fits on the stock turbo exhaust manifold, then it's a hybrid.
We can't figure out what exact compressor wheel is on it unless you pop off the compressor housing and measure the wheel.
-Ted
Old Oct 27, 2005 | 12:13 AM
88t2romad's Avatar
(_8(|)
-Ted
ok, comp housing is off, what exactly do you want me to measure? (I know you mean the wheel, but i mean like dia at base of wheel? or dia at tip of blades?
Old Oct 27, 2005 | 01:10 AM
2a+RoN's Avatar
both are needed to tell what compressor wheel it is.
Old Oct 27, 2005 | 01:30 AM
88t2romad's Avatar
(_8(|)
ok, thanks. Ill get back with that info tommorow
Old Oct 27, 2005 | 03:06 AM
RETed's Avatar
Get major and minor diameters - dial calipers will help here.
http://fc3spro.com/TECH/TURBO/tmodels.html
-Ted
Old Oct 27, 2005 | 09:13 AM
RacerXtreme7's Avatar
NASA geek
S5 hybrid, T04e comp, probly a 57 trim, but yeah, exact measurements needed.
~Mike.............
Old Oct 27, 2005 | 10:06 PM
Rotortuner's Avatar
Undercover
Got those measurements yet?
Old Oct 28, 2005 | 12:15 AM
88t2romad's Avatar
(_8(|)
er...i dont have anything to measure it, i wish i had a micrometer or somehting along those lines. Ill look around my appt, maybe i got somehting.
Old Nov 16, 2005 | 01:43 PM
88t2romad's Avatar
(_8(|)
ok, got it measured.
Intake side
Minor = 2 5/16 (2.301) (cm=5.715)
Major = 2 3/4 (2.75) (cm=6.985)
Turbine side
I only have the minor since the housing is still on.
Minor = 2 1/4 (2.25) (cm=5.715)
After looking on the link ted provided, looks like a "h" trim compressor. Who wants to confirm thats a lil more "turbo knowledgable"
Old Nov 16, 2005 | 02:01 PM
NASA geek
Its a Hybrid s5 turbo with a T04B H-trim compressor wheel and a T04B comp housing in a .7 A/R value. Your turbine wheel has been clipped. Going by your rough measurements, its most likely a O-trim T4 turbine or T3 stage III. It has the curved vanes/paddles/impellers as opposed to the stocker (which has smaller exducer) flat "impact" type vane/paddles on the turbine wheel. Make sure the wastegate is HEAVILY ported or your gonna have issues with boost creep. This hybrid is probly good for 350 rwhp give or take 20 dependant on the other systems in the engine set up and tuning.
~Mike.............
Old Nov 16, 2005 | 02:49 PM
88t2romad's Avatar
(_8(|)
Thanks a lot!
I wont be using it, its pending sale.
Ill be going with a GT35r
-Ben
Old Nov 16, 2005 | 04:49 PM
NASA geek
OOPSY!!
I forgot it has a 6 paired impeller and went strictly on your measurments. Are you sure the major diameter is 2.75"?? It looks to be a T04E, but your measurements I'm guessing were done with a ruler or something and not accurately done with a caliper or micrometer. The measurements need to be rather precise. I'd still say either a T04E 57 or 60 trim..... both wheels being better then the T04B H trim.
~Mike.............
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
