Traxmition question.......
Old Oct 26, 2005 | 11:09 PM
mazdaspeed87's Avatar
every shift into 2nd grinds bad but only at about 5-8000 rpm. is that my syncro or clutch or something else......help
Old Oct 26, 2005 | 11:11 PM
Icemark's Avatar
Try changing the gear oil to redline MT-90.
It will take about a 100 miles for the redline to work its way in, but that should help the bad syncro
Old Oct 26, 2005 | 11:16 PM
Juiceh's Avatar
Saiga-12 Power!
Are you trying to shift quick? If you slow your shifting does it go away? If so then its probably the synchro, sounds like it is. Mine grinds when I keep it below 4k for breakin but shift fast. Good thing the replacement is on the way.
Old Oct 26, 2005 | 11:31 PM
yeah i shift quick but it will do it even when i shift slow when my engine is cold.... and i cant fild red line anywhere but i heard this purple something is realy good as well. and just wondering how much is a 2nd gear syncro....?
Old Oct 26, 2005 | 11:59 PM
Juiceh's Avatar
Saiga-12 Power!
Royal Purple I believe is what your thinking of. I've heard good things about Neo tranny fluid too on this forum.
Old Oct 27, 2005 | 02:17 AM
KompressorLOgic's Avatar
I
to replace the syncro is to rebuild the whole tranny esentially... that can cost alot....
i would first try using redline oil in it as that might give you some more life out of it before it becomes worse.
Old Oct 27, 2005 | 06:42 PM
well i go to OUC geting my auto teck aprentiship so i have all the tools and time to do it so i would like to get it done before winter and i getpart for dirt chead i can get the whole clutch kit for $100 and syncros for 40 so its not a big deal. but i just want to know if every one agrees that its the syncro.
Old Oct 27, 2005 | 07:24 PM
MrDirt's Avatar
Shifting too fast OR too slow would usually make a bad synchro grind the gears. Just try to learn how to match your gears better on up and downshifts. That, combined with some of the other suggestions (the synthetic gear oil) should clear up a lot of your problems.
Old Oct 28, 2005 | 03:09 PM
so you say dont bother with a rebuild?
Old Oct 28, 2005 | 06:42 PM
custom13B's Avatar
Unless youv rebuilt a manual transmission before I wouldnt suggest doing it. Special tools are required and you cannot disassemble certain gears without these special tools. Its more complicated than you would think...I've done it. If you want to rebuild the tranny have a transmission specialist do it. Of course that wont be cheap. If you want cheap get a used tranny. Either way youll have to remove the tranny which isnt a big deal. Also suggest replacing the pilot bearing while its removed,but your call. Good luck.
Old Oct 28, 2005 | 09:13 PM
ok well i have all the special tools you can think of. like i said im at school rite now with a tool room the size of i dont know... BIG. So thats not an isue. and my instructor is tranny specialist. but i dont know if i want to do that. i do have a tranny with 130k on it minr has 170k and tha130is out of an 88 and i have an 87 dont know if its in any beter shape but i will swap it and see i shoul;d take me one or two classes.... good idea?
KingFish
23
May 3, 2005 11:13 PM
OnlyOnThurs
Mar 7, 2005 04:23 PM
jimtesla
Aug 8, 2003 03:33 PM
drewthrewpoo
Nov 13, 2002 10:20 AM
