A Little Taste: PFS tuned and built ......w/..GT 42R
Old Oct 26, 2005 | 06:23 PM
ErnieT's Avatar
Living life 9 seconds at a time
Ray has ported and clearanced my engine for the high boost I want to run (30+psi) and has modded the GT42R kit I bought, to work. The turbo kit is from A-Spec. The hood has to have one of the braces taken out for it to close as the manifold from A-spec had the turbo a bit high. Although Ray had to do some modifications for it to work, its looking good. Hope to be done and tuned by Friday, Nov. 4.
I want to give huge props to Ray. He has went out of his way to fix alot of things for me with the motor, turbo kit, wiring, ...........hell just about every damn thing under the hood!
Attached Thumbnails A Little Taste: PFS tuned and built ......w/..GT 42R-dscf00731.jpg   A Little Taste: PFS tuned and built ......w/..GT 42R-dscf00742.jpg   A Little Taste: PFS tuned and built ......w/..GT 42R-dscf00753.jpg   A Little Taste: PFS tuned and built ......w/..GT 42R-dscf00764.jpg
Old Oct 26, 2005 | 06:36 PM
Turbo II-FB's Avatar
damn .....Nice set up what #'s do you expect to be putting down? Have you broken in the motor yet?
Old Oct 26, 2005 | 06:42 PM
ErnieT's Avatar
Motor will be broken in on the dyno and Im expecting over 600rwhp.
Old Oct 26, 2005 | 06:45 PM
turbodrx7's Avatar
PURIST
HA, thats nothing...lol nice setup, it looks good ET! Now if you live long enough to get to Imports vs domestics...hmm
Old Oct 26, 2005 | 06:51 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Looks awesome man!!! Sorry I had to go on IM....I'll hit you up and talk to you about it later, I was in a hurry.
Stephen
Old Oct 26, 2005 | 07:08 PM
CANRX7GX's Avatar
PREDATOR
DAMN that's a huge turbo!! let us know your numbers when you get 'em
Old Oct 26, 2005 | 07:49 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Hey Ernie, is that the T4 housing or the T6 housing? The pictures look great by the way! I can't wait to see what kind of numbers you'll be putting down.
Zach
Old Oct 26, 2005 | 08:04 PM
AZ'sFastFD3S's Avatar
Boy that setup looks alot like mine. Why is the turbo up so high? How long are the manifold runners? Are they equal length? I would love to run 30+psi on my car. I dont have the ***** though.
Matt
ErnieT's Avatar
Zach
T6 frame, the big boy!
Old Oct 26, 2005 | 08:06 PM
ErnieT's Avatar
Matt
The turbo does sit up a bit high, but yea the runners are equal.
Old Oct 26, 2005 | 08:20 PM
88fc3sw/HX83's Avatar
Ernie, if you're going to run 30+ psi with an aggressive tune, you'll be over 600 rwhp easy!
Old Oct 26, 2005 | 08:25 PM
kabooski's Avatar
Laying Down Rotary Law
make sure you get nice cold plugs
11's NGK
don't try tighten them
enough where they don't come loose
(you don't want a electrode coming off and into your engine)
C16 with some Premix oil
and your good to go
Old Oct 26, 2005 | 08:42 PM
Fd3BOOST's Avatar
Recovering Milkaholic
That thing is ridicoulous. I held that turbo and I swear it weights as much as a 45lb plate from my weider bench. Good luck with it and see you at MIR.
Old Oct 26, 2005 | 08:47 PM
LUPE's Avatar
Looks big and powerful.
Old Oct 26, 2005 | 09:39 PM
CCarlisi's Avatar
Rebreaking things
Nice setup Ernie. Do you have any closeup pics of the turbo in the engine bay? -Same question for you AZ'sFastFD3S. I'm trying to see where you guys mounted them in relation to the shock tower, box supports around the tower and LIM.
I have heard nothing but good things about Ray Wilson. I think your project is in great hands.
Old Oct 26, 2005 | 09:46 PM
Zero R's Avatar
Just in time to die
The runners are exactly equal length, it sits as high as it does because of runner length and it allows more options for IC plumbing and a few other little things. It's looking good. Can't wait to see it perform. Should do really well!!
Old Oct 26, 2005 | 10:05 PM
cripsR6's Avatar
11.7@128
Attached Thumbnails A Little Taste: PFS tuned and built ......w/..GT 42R-caedblgg.jpg
Old Oct 26, 2005 | 10:40 PM
ErnieT's Avatar
Ray took these pic's. I'll post a ton next week when I pick up the car as well as dyno sheets......
Old Oct 26, 2005 | 11:14 PM
that turbo could eat a freakin baby
Old Oct 27, 2005 | 03:00 AM
bcty's Avatar
Boost This!
nice to see you went eh gt42 route..
600rwhp is easy p cheezie youll have lots of fun
post more pics when its all buttoned up
Old Oct 27, 2005 | 07:19 AM
KNONFS's Avatar
B O R I C U A
That's a hughe biatch
Hope to see it at MIR
Old Oct 27, 2005 | 10:53 AM
PDViper77's Avatar
HAHA V8
That's diesel.
Old Oct 27, 2005 | 11:18 AM
rotorbrain's Avatar
fart on a friends head!!!
i know its a little late, but i had a bit of a problem with this as well with my engine re-install. i thought it had something to do with my car being out of whack or something. . . but i was wrong. i installed the motor w/o correctly aligning the engine/transmission to the PPF. get under the car with a jack, support the transmission with said jack, and loosen the corresponding PPF nuts. then with said jack, jack up the transmission until it levels out the engine in the bay. i had serious problems with my exhaust and bov rubbing on everything because of this. when i finally figured it out. . . it made things A LOT easier.
that maybe what your problem is, as well. just try that and see if it helps. especially if youve had exhaust alignment problems lately.
Old Oct 28, 2005 | 02:23 PM
Scrub's Avatar
bow leggin'
So I guess this will be one hell of a road course car
Seriously though you're nuts. I gave you a ride in my car, now it's my turn to get a ride in yours when it's all done. Congratulations, can't wait to check it out.
-Dan
Old Oct 28, 2005 | 07:35 PM
ErnieT's Avatar
-Dan
You can ride shotgun during test and tune Nov. 6. I'll be running only 30psi
