Pineapple Racing is Moving...
Old Sep 29, 2005 | 03:17 PM
Blake's Avatar
Our landlord decided to jack our rent 38% at the end of our lease (dumb move in this market!), so Pineapple Racing is relocating over to Airport Way, about half way between 122nd and 138th, on the south side of the street. The address is 12838-B NE Whitaker Way, Portland, OR 97230. This is directly across the street from Horsepower Freaks. The signage is not up yet, so look for Gasket Specialties...we're next to them, in Bulding 4, facing the street.
The new shop is about the same size, but we are no longer leasing out half to GT Garage (Chris has moved his shop to North Portland), so it will really be quite a bit more space for us. Our new complex also has 24-hour on-site security with a 60-second response time.
We will be competely out of the old shop on Whitaker Way by the end of the week. It will take some time to set up the new shop, as there is a LOT of stuff to rack and equipment to set up. After we get settled in, we will invite everybody to come over and visit us. Perhaps have a barbeque or something. Anyone interested in a Compression Check day, similar to a dyno day but with a Mazda Digital Compression Checker? Perhaps just a tech seminar? Let us know what you'd be interested in.
We are hoping to have a smooth transition with the phone (same number) and internet access, but if you have a problem getting a hold of us, please be patient. It's possible we will be out of touch for a few days, depending on things outside of our control. We're going to be pretty busy just setting the new shop up, anyway.
Here is a map, showing the old and new locations:
Blake Qualley
Pineapple Racing
Old Sep 29, 2005 | 03:26 PM
islanders_rx7's Avatar
That sounds great!
Old Sep 29, 2005 | 03:36 PM
The Spyder's Avatar
Never give up!
Cool guys. Glad to see your doing well. Cant really say I see chris moving out is a bad thing.
Old Sep 29, 2005 | 04:12 PM
Cough XAS
Only if they could move to Washington, I'd be a happy camper.
Old Sep 29, 2005 | 04:19 PM
Talking
I am a happy camper they even moved closer to me.
Old Sep 29, 2005 | 04:51 PM
RotorJoe's Avatar
Hooray For Boobies!!!
s
I was hoping a touch closer also.
But the compression check sounds like a good idea.
Would you be doing this with a Mazda Compression Tester?
Would you connect up and good battery also?
Just wondering about the difference in numbers due to the cranking/RPM speeds while testing.
Tech day would be cool too.
Good Luck in the move and have fun in the new shop.
Old Sep 29, 2005 | 05:46 PM
Compression check and tech sounds cool. Good luck on the move.
Old Sep 29, 2005 | 05:55 PM
Blake's Avatar
Originally Posted by x605p747R1
s
Keep in mind, as an Oregon shop, we charge no sales tax, even to Washington residents.
Yes, we have a Mazda digital compression tester. I even had some compression test slips printed and padded, so you can have a record of the test to keep with your maintanance records, or in the glovebox. We may also make some decals to stick under the hood. Cranking RPM is important, but there is a simple, linear function to determine the relationship (e.g. 5.0 cg/cm^2 at 200 rpm = 7.0 cg/cm^2 at 300 rpm). Here is the graph on our comp check pads:
BTW, it's probably obvious, but in the first paragraph of the first post, I accidently said 12838-B NE Whitaker Way....I meant, of course, 12838-B Airport Way. D'oh!
Old Sep 29, 2005 | 06:27 PM
RotorJoe's Avatar
Sweet Thanks,
No sales tax, I forgot about that. Right on.
The thing that gets me is when you jump out to pump your own gas, some guy comes running out and pushes you away. I always forget it's not self serve. Plus do you have to tip those guys?
Not to change the subject or anything.
Old Sep 29, 2005 | 06:45 PM
Blake's Avatar
Sweet Thanks,
Yes, it's weird. One of those full-employment laws left over from the 70s. But it doesn't really cost anything more, because our gas tax is less. It used to be the cheapest gas was somewhere between Seattle and Portland (Centralia, Vader, Woodland, etc.) but for the last couple years, gas is always seems cheapest in Portland. I just wish they would stop pretending that the no-self-serve pumping was some sort of safety issue!
Anyway, back to our regularly scheduled programming...I'm about to pack up my office and have no idea how quickly our phones and DSL will be back up, so I may only be able to post from home (and I won't be seeing much of home until our move is done). See you on the other side.
Old Sep 29, 2005 | 07:37 PM
pp13bnos's Avatar
Pineapple Racer
Whats sad is that I never had a engine built in that shop. The old one in SE Portland built pretty much all of my toys over the years. Lets see...there was the 12a Peirpheral engine with no rotating mass for my 81 Rx-7, the monster street ported 13B fore my REPU, the injected 13B Peripheral with the nitrous for my REPU, and my daily driven small street port for my old n/a 90 Rx-7.
Back on topic, I wish you guys would have moved south a wee-bit further. Like Wilsonville.
CJ
Say Hi to Rob for me Blake.
Old Sep 29, 2005 | 08:26 PM
Hyper4mance2k's Avatar
The Shadetree Project
I got an Idea! You guys should expand! Open a second shop up in Seattle, and hey I'll run it for you! I'm cheap labor, well not too cheap! Hey business management doesn't come cheap anymore! LOL
Old Sep 30, 2005 | 02:39 PM
z-beater's Avatar
REW'd FB
Yes I agree stay in Oregon...
Old Sep 30, 2005 | 03:00 PM
Jeff20B's Avatar
Lapping = Fapping
I'd work at the second shop in Seattle.
Old Sep 30, 2005 | 03:47 PM
Kouta's Avatar
Mystical wings guide me~
Sounds awesome, I only drove down to portland once. I really don't like that long stretch of road thats 70mph on it... way to easy to go 90+ down. Thank goodness when I got pulled over I was only clocked at about 82, and I got off with just a warning
Back on topic, I wish ya guys a quick and easy move, and sucks ya have to move, but hopefully it will be for the better.
Old Sep 30, 2005 | 09:51 PM
rotarysc's Avatar
Congrats Blake n Rob... You guys are the top dogs in Rotary Engines in the NW. Cya at ABF06 hopefully?
Old Oct 2, 2005 | 03:54 PM
banzaitoyota's Avatar
What Subscription?
Just wish I could enjoy the experience of a Quality engine from Pineapple
Old Oct 3, 2005 | 12:20 AM
Blake's Avatar
Would you give it a rest already? Everyone knows you were dissatisfied with your dealings with Pineapple...and rightly so. We let you down. Twice, even. That's the one and only time that has ever happened and hopefully the last. If you will look around, no one but you seems to have had such an experience. And, you were offered a refund but chose not to take it. The guy who built your first motor (cracked plate) hasn't worked for us for, what, two years now? You were not ripped off, so I fail to see why you feel the need to twist the knife at every single opportunity. Say your peace and please move on. This thread is about Pineapple Racing relocating to a new building. If you don't have something to say that is ON TOPIC, please don't post. There is a good guy, bad guy section intended for this very purpose. Please be sure to include that you were not ripped off financially; only dissapointed with the work. Perhaps business will slow down enough for us to actually take a day off once in a while, rather than suffer through a perpetual month-long backlog of work.
Old Oct 3, 2005 | 12:28 AM
Blake's Avatar
Update on the relocation:
We are now entirely out of the old facility and in the process of setting up the new shop. Our phone service will not get resumed until the middle of next week and we will temporarily have a new number until the transfer request goes through (we are changing phone companies and we have to have service before they can file the number transfer paperwork). We also have to go from Cable Modem to DSL and that will also apparently take a bit of time and effort to get up and running. Hopefully we can get a lot accomplished in the next few days, so when we get back from Sevenstock, we can start being productive again.
Old Oct 3, 2005 | 12:32 AM
CODE BLUE 2's Avatar
Resident Bitch
I agree with blake on this one banzaitoyota. Please take this to the "Good Guy bad Guy Section" if you still feel the need to post that you are a dissatisfied customer with Pineapple, but don't do it in this thread. Thanks
Old Oct 3, 2005 | 12:44 AM
turbojeff's Avatar
Do it right, do it once
Blake,
Just curious, what is your position at Pineapple?
Jeff
Old Oct 3, 2005 | 12:04 PM
Blake's Avatar
Originally Posted by turbojeff
Blake,
Jeff
I'm half-owner of Pineapple Racing, Inc. which is the parts-side of the house (engine stand adaptors, 6-port inserts, alt relocation brackets, FD airpump elimination pulley kits, etc). "Powered by Pineapple Racing, Inc." is the engine building service, which I do not have a financial stake in. In the near future, the "parts" business will start selling ready-built engines under a different brand name.
Old Oct 3, 2005 | 12:50 PM
Kouta's Avatar
Sounds like your getting all set up right. Good luck with the rest of the stuff
Old Oct 3, 2005 | 07:35 PM
KompressorLOgic's Avatar
I
a compression check day and BBQ sounds fun
maybe could have compression competitions!!! with prizes!!!!
compression competition catagorys
1. highest compression/RPM
2. lowest compression/RPM
3. largest AVG. comp difference between F and R.
4. most uneven compression between 2 chambers in 1 rotor
5. highest cranking RPM
6 lowest cranking RPM
that way even if your motor sucks u can still be a winner! haha
Old Oct 3, 2005 | 09:07 PM
pp13bnos's Avatar
Pineapple Racer
I'd love a compression test day! CJ
