Microtech premix with microtech?
Old Sep 23, 2005 | 03:11 AM
kd86rx7's Avatar
do i run premix if i get the microtech lt8x? if so wat do i do with the omp then? thanks
eric.
Old Oct 1, 2005 | 06:50 PM
rotan20b's Avatar
I would only run premix fuel if you have removed the oil met. pump form your motor.
Old Oct 5, 2005 | 02:37 PM
TonyTurboII's Avatar
Glock Lover
Depends, if you have a mechanical oil metering pump, I would leave it in place. Probably clean it up though, can get some new lines. If it is electrical I would block it all off and premix, I dont think you can run it with the ECU.
Old Oct 5, 2005 | 04:25 PM
TwistedRotors's Avatar
Compression Tester Guy
S4 mechanical OMP will not be affected, however the S5's electrical unit can not be controlled by a Microtech. If you have an S5, remove the OMP, block it off and run premix.
-John
Old Oct 7, 2005 | 07:41 AM
fastcarfreak's Avatar
3rd motors a charm I hope
The microtech has no way of controlling the electric OMP. I just left mine on and unplugged. I run about 1 ounce of premix per gallon of gas. So that would put it at about a 1:128 premix to fuel ratio.
Adam
Old Oct 7, 2005 | 08:50 AM
Broken09's Avatar
I am becoming...
I'm premixing as well.
Old Oct 7, 2005 | 01:31 PM
sunshine's Avatar
I installed an S4 front cover, and mechanical OMP onto my S5 block when I was building it. I knew that I was going to use the LTx8 already, so the project was planned accordingly.
It was a pain in the a** to do the conversion, but its worth it. This way, I dont need to premix out in the cold when winter starts
-A
Old Oct 8, 2005 | 10:27 AM
-A
You shouldnt be driving your car out in the winter in CT anyways! lol. Snow and rx7s do not mix. Especially rx7s that are modded and have standalones. lol
20B Forum
21
Mar 22, 2022 01:00 PM
Andrew7dg
Aug 6, 2017 01:41 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
