Running Ball Bearing
Hey guys,
Don't know much here, but I read somewhere that running a ball bearing single turbo was not optimal for a rotary motor. I also heard that in Japan most people don't run ball bearing turbos on rotaries. Now, since the GT series turbos are so popular in the states I'm guessing that it's probably fine, but I was just wondering if someone could explain why a ball bearing turbo would not be optimal. Just more for my edification. Thanks.
Victor
Victor
I'm just guessing, but it could be due to debris in the oil causing durability issues with the ball bearing setup. Rob at Pineapple recommended prefiltering the oil before it goes into the turbo. This is just a guess so don't qoute me on this.
It shouldn't matter wether it's piston or rotary though.
Originally Posted by Zero R
Just picking on Vic.
Trending Topics
Curious about this issue myself, so I did a search and found this link. Google info suggests there is a good discussion here about this topic, but you gotta log in to get there.
http://www.nopistons.com/forums/inde...49204&view=new
One drawback to running ballbearing turbos on a rotary----when (not if, when) you blow, chances are good an apex seal piece will take out your turbine as it passes out the exhaust port. Rebuilds on bb turbos are freaking expensive.
Azevedo
26
Mar 1, 2019 09:19 PM
tallbozo
Aug 15, 2015 02:47 PM
Gotta take care of my customers.
