720cc injector question.
Old Sep 9, 2005 | 07:27 PM
rhythmfunk's Avatar
I live in California (SMOG) and Im looking to upgrade to 720cc injectors. If I put in these without a AFC, will they put in more fuel from the start? Is there a way to keep output like stock? I want to know if I will have to tear down the UIM after smog or if I can install with the engine appart before hand.
Thanks!
Old Sep 9, 2005 | 08:10 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Are you planning to use them for your secondaries only? If so then it doesnt matter in regards to starting or even revving unless you are at 3800+ rpm under load. If you put them in the primaries yes they will add more fuel, maybe even flood them. For what it's worth a piggy back like an SAFC cannot control them during cranking anyways but the stock ecu cannot tell that they are bigger injectors.
Taking off/putting on the UIM is no big deal you can put them in before or after it doesnt really matter.
Old Sep 9, 2005 | 08:12 PM
k-rok's Avatar
PHOTOSHOPPER!!
youll need a SAFC to manage the fuel ratio, or an e-manage like me, why did you upgrade in the first place, any big mods, or just felt like sucking up the wrath of Katrina's gas prices???
Old Sep 9, 2005 | 08:40 PM
NZConvertible's Avatar
I'm a boost creep...
Any time you exceed 3800rpm, yes.
You just answered your own question. You need a fuel controller.
Old Sep 10, 2005 | 12:36 PM
rhythmfunk's Avatar
they are secondaries
I havent upgraded yet, but once Im done with smog, Im increasing stock boost, opening the ehuast up and want to make sure theres enough fuel. I also plan to make sure I have a pump that will keep up.
So having them wont effect smog?
Old Sep 10, 2005 | 08:55 PM
If the smog test takes the engine over 3800rpm, yes!
Don't **** around with half-assed mods. Get the injectors and a fuel controller and get it properly tuned.
Old Sep 12, 2005 | 06:59 PM
rhythmfunk's Avatar
I havent taken any short cuts yet and dont plan to. It's not worth it to me to be cheap.
Thanks~!
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
tidanb0utch
11
Oct 7, 2015 07:36 AM
