okay this is confusing
Old Sep 9, 2005 | 05:03 PM
Rx7MPGUY84's Avatar
Rpm abuser
Well like i said the other day, the rx7 is running, but i only had it running for a couple mins. I had to replace the coolant pressure cap for the radiator. Well i put it on today, and tried to start it (didnt start) and thought it was just over flooded like always for my car. so i look around, and see that theres coolant leaking. between the irons and the housings. I opened up the new cap and it was pressureised. What to you guys think. i did the tension bolts for the motor EXACT to the stock spec. what do i do?? I made sure all my seal were in right. god i hate being confused.
Old Sep 9, 2005 | 06:53 PM
Rx7MPGUY84's Avatar
Rpm abuser
**** me thinks i might of fucked up one of the coolant seals and that im pressurizing the whole coolant system. what do u think? could it be possible. i sat that mother down like 4 times making sure it didnt pinch thouhg. god id hate it if i had to part out my motor
Old Sep 9, 2005 | 07:01 PM
BuffDaddy915's Avatar
Tha ladies man
Sounds like it was pressurized and created a leak becuase of too much pressure. Might have had a seal or something that was weak and once it was pressurized it couldn't hold. Might be a small leak, might be why there's still pressure?
Old Sep 9, 2005 | 07:09 PM
SonicRaT's Avatar
Super Raterhater
That or it's leaking from somewhere else and it just looks that way, though that's not as likely.
Old Sep 10, 2005 | 03:45 PM
Rx7MPGUY84's Avatar
Rpm abuser
well i think i pinched a coolant seal. that is a big possibility, i found a peiceof plastic on my rear spark plug. Im guessing its pinched. oh well. time to part out. check for my for sale. its being stripped somtime tomarrow or sometime else this week.
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
c0rpse
16
Sep 25, 2015 11:33 AM
doritoloco
Sep 5, 2015 12:41 PM
