A quick one...
Old Sep 9, 2005 | 03:27 PM
aznraver's Avatar
A quick one...
Hi , I used to own a FD3S when I would turn the key on...I would hear the fuel pump working.
Is it the same principal for the FC???when you turn ignition on ...are you suppose to hear the fuel pump working...? if so i might have found the problem of the FC not starting
Old Sep 9, 2005 | 03:44 PM
aznraver's Avatar
any one?
Old Sep 9, 2005 | 03:45 PM
kungfuroy's Avatar
Chicken Adobo
The fuel pump turns on when the key is turned into START. Once the car has started, it stays on wehn the key is in the ON position. You can see if the pump is working by putting the key in ON, then jumping the fuel check connector near the passenger side strut tower, or you could push in the AFM flap. You should be able to hear the fuel whirring if you put your ear by the fuel rail
No bumps man, especially after a few minutes
Old Sep 9, 2005 | 03:52 PM
aznraver's Avatar
Oh boy..now time to uncode that information ...lol thankx
Old Sep 9, 2005 | 04:09 PM
kungfuroy's Avatar
Chicken Adobo
OK then no, the fuel pump does not just turn on when the key is turned into the ON position from ACC.
Old Sep 9, 2005 | 04:17 PM
aznraver's Avatar
Thankx a last one...on the green connector. You have a ground and two other lines...how do i jump?
Old Sep 9, 2005 | 04:25 PM
kungfuroy's Avatar
Chicken Adobo
If I remember right, it is a yellow connector with only 2 terminals. To jump, connect the 2 terminals with wire. Have you gotten the FSM or a Haynes?
Old Sep 9, 2005 | 04:31 PM
aznraver's Avatar
i just did thank You
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
eplusz
15
Oct 7, 2015 04:04 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
