Turn signals failed?
Old Sep 9, 2005 | 05:53 AM
Ni5mo180SX's Avatar
White Comet
So today I was driving to school when i noticed the left turn signal blinking erratically. I couldnt tell if this was just glare or the signal but it went away.
So later in the evening it happens again and I can tell its the signal. I try hitting the left and right arm but no good. When I touch the hazards it goes away. Then I hit a bump in the road and it comes back and I hit the hazards again and it goes away. Now my turn signals won't work. I can hear it click but no lights. Any ideas on where to begin or what could cause this? Thanks!
Old Sep 9, 2005 | 08:06 AM
Icemark's Avatar
when you say erracticly do you just mean flashing fast (which once again would be the CPU indicating a bulb failure or short) or do you really mean erracticly as in no pattern (which would indicate a CPU failure and the CPU's flasher board would need to be replaced.
And I do have rebuilt CPU flasher boards available on my website
Old Sep 9, 2005 | 09:23 AM
Ni5mo180SX's Avatar
White Comet
Thanks for giving your input on this one.
I mean like really erratically as in like left then right or both together blinking in different variations of fast.
Where is the CPU located? You don't think it could be some wiring short in the actual gauge consoles wiring or is this commonly associated with what you named? Thanks again.
Old Sep 9, 2005 | 09:27 AM
Icemark's Avatar
well again. if you have a bad bulb then the side with the bad bulb would be flashing faster than the side without the bad bulb.
the CPU is the black box next to the fuse box in the driver's kick panel
Old Sep 9, 2005 | 09:29 AM
Ni5mo180SX's Avatar
White Comet
No they were flashing without me touching any controls that have to do with them. Im pretty familiar with how the bad bulb flash is and this was a bit different.
Old Sep 9, 2005 | 09:45 AM
Icemark's Avatar
do the hazards work ok or are they messed up too (they use the same circuit in the CPU)
Old Sep 9, 2005 | 09:47 AM
CyborgRyu's Avatar
Drift FC
man....it was a week of turn signal failing lol.
5th or 6th thread so far.
Old Sep 9, 2005 | 09:51 AM
Ni5mo180SX's Avatar
White Comet
wth haha
Hazards dont work.
Old Sep 9, 2005 | 09:56 AM
Icemark's Avatar
probably a bad CPU then
Old Sep 9, 2005 | 01:57 PM
slow_2ed_gen's Avatar
my left turn signal works fine, left one doesnt work at all no light inside or out. hazards on the left one only works. is that the switch?
on a similar note my brights will flash but wont stay on
Old Sep 9, 2005 | 02:20 PM
Icemark's Avatar
No, it is the CPU flasher board that needs replacing- I have rebuilt ones available on my webstore/website
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
m_haiser
Sep 13, 2015 04:21 PM
