Just ran 12.8 @107 Atco,NJ
Old Aug 27, 2005 | 09:32 PM
Silverfc88's Avatar
Ran 12.8@107 at around 11psi (10.6).
VID:http://home.comcast.net/~IMPREZvWRX/RX7.wmv
See mods here:http://www.tristatetuners.com/forum/...do=view&id=126
Number 203
Old Aug 27, 2005 | 09:36 PM
sleeperfc's Avatar
MP T-70 = Fun
slicks or drag radials? 1.8 60' foot says one or the other
with rpm did you launch at?
mods will move this to the dyno and time slip section soo i bet.
edit:
Mickey Thompson ET Streets 255/50R16 on the stockers (Track wheels)
was in the mods list... oops.
Old Aug 27, 2005 | 09:42 PM
Silverfc88's Avatar
I usually launch between 5-5500 rpm.
Your right on the drag radials. Going on street tires suck the best 60' I could pull was 2.1. Launching on the drag radials feels so much better.
Old Aug 27, 2005 | 09:44 PM
Whizbang's Avatar
Respecognize!
im getting about a 2.1 -2.2 60ft myself. i might have to go get some better tires.
that and do you have any problems running a atomsphereic BOV? or did you get rid of the AFM.
Old Aug 27, 2005 | 09:47 PM
Silverfc88's Avatar
No I haven't had a problem running the open BOV and I still run the AFM.
Old Aug 27, 2005 | 09:48 PM
88IntegraLS's Avatar
Displacement > Boost
Congrats, and it's good to know what's possible with a 108 trap speed.
Old Aug 27, 2005 | 10:03 PM
eriksseven's Avatar
Make Money.
good run!
That's impressive for only running 11psi.
Old Aug 28, 2005 | 12:10 AM
88t2romad's Avatar
(_8(|)
nice run, thats kinda impressive on 550's and 720's......at least i think it is
Old Aug 28, 2005 | 01:44 AM
just startn's Avatar
Turbo vert
Sounds like things are goin good for u so far. if u could get it to 12s flat constantly without brakin anything that would be real nice
Old Aug 28, 2005 | 04:36 AM
RETed's Avatar
Nice run...
255/50/16 is an awefully big tire compared to stock.
Are you able to stay in 3rd gear through the traps?
Or are you shifting into 4th?
-Ted
Old Aug 28, 2005 | 08:56 AM
Silverfc88's Avatar
Yeah I'm getting close to maxing the injectors. I have plans of going bigger so I can turn the boost up a little.
The tires are big for the stock wheels and a little to tall, but they have worked so far. A great improvement at the strip. I only run them at the strip then swap rims again before I go home. Trying to run on the strip on 17's is futile.
I am in 4th at the end and I shift around 7,000.
Old Aug 28, 2005 | 04:08 PM
Silverfc88's Avatar
Awesome got some pics to.
Old Aug 28, 2005 | 06:48 PM
88rxn/a's Avatar
tom port.. AKA streetport
impressive!! if ya get the new injectors you should do pretty good!
Old Sep 1, 2005 | 12:07 PM
lucky7ruski's Avatar
Newbie
did you say u have the oil metering pump removed ? how does that work how do u replace its function ? i have an 88 turbo with mech oil metering pump and i put in a 91 turbo in and the 91 oil metering pump is electronic any ideas on how to make it work
mech ones doesn't match up and wireing harness doesn't have connector would i have to replace the computer ?
Old Sep 2, 2005 | 02:28 AM
bigdv519's Avatar
IFO Forced Induction Slo
Now thats impressive....just impressive!!! Hats off to ya.
Old Sep 5, 2005 | 04:09 PM
SmogSUX's Avatar
No money. No love.
You dump it at 5500? Haven't broken any rear ends? Or you just feather it out fast?
Old Sep 5, 2005 | 04:34 PM
jacobcartmill's Avatar
just dont care.
dude its pretty hard to break TII rearends...
nice run! needs more powershifting though. you prolly coulda had atleast a 12.7 powershifting... and as far as the 108mph, not bad... i actually trapped the exact same (i think 107.8 or something) on my t04 "stage1" hybrid.
nice!
Old Sep 5, 2005 | 05:57 PM
SmogSUX's Avatar
No money. No love.
Rearends hold up on street tires, but if you dump the clutch with radials or slicks at 5k....thats a bit much :P
Old Sep 5, 2005 | 09:57 PM
just dont care.
i have never heard of anyone breaking a s4 TII diff.
Old Sep 6, 2005 | 10:32 AM
gsracer's Avatar
EIT
I'm sure someone continually dumping the clutch at 5500 on some M/T or other slicks would probably break a rear end eventually. Nice runs.
Old Sep 7, 2005 | 03:48 AM
SmogSUX's Avatar
No money. No love.
Still wow...my car is modded a lot more...can't wait to see what I run now ^_^
Old Sep 9, 2005 | 02:47 PM
gerbraldy's Avatar
wtf's a piston
It's a ford 8.8" rear, they won't give you any problems with anything less than 450+hp.
The car looks really really nice, I love the cap for the TII hood.
Old Sep 30, 2005 | 03:25 PM
Silverfc88's Avatar
I always try to launch around 5500 now, but I'm still going to experiment. I used to rev lower but I would bog more often then actually launch. I also have a lightened flywheel so maybe that has something to do with it.
I haven't had a problem yet with the rear end. Cross my fingers and hope it holds up.
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
musker
Oct 1, 2015 05:58 PM
