what does this hose on the intake do?
Old Jan 9, 2002 | 10:56 PM
slopoke's Avatar
i was wondering what the hose that hooks to the intake and wraps around the back of the motor does. thats pretty much all, thanks, scott
Old Jan 10, 2002 | 12:16 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
wraps around the back of the engine? hmm that would prolly be the hose leading to the rear turbo.
Old Jan 10, 2002 | 03:20 AM
Wargasm's Avatar
Weird Cat Man
Are you talking about the 1/2 inch hose that goes from just before the throttle body to the back side of the intake manifold? It's right near the firewall? That's for the AWS (accelerated warmup system).
If you are NOT talking about that but are instead looking at a rubber with metal in the center section hose... that goes from passenger side of the upper intake manifold, along the firewall, and then to the brake booster... that is for the power assist on your brakes.
Brian
87 TII
93 R1
Old Jan 10, 2002 | 04:29 PM
slopoke's Avatar
i was refering to the hose that is about 1 inch diameter and that hooks to the back of the air intake box and goes around the back of the engine, sorry for not being more specific. there is one for the bov one for the crv valve and one for the air pump, then one that goes around back. the other two are the big ones for the turbo air intakes, i was jsut curious what the mystery hose that goes around back of the engine does, thanks. scott
Old Jan 10, 2002 | 04:34 PM
Chadwick's Avatar
Mr Sparkles
You have 2 that come from BoV's (Officially CRV's). Both connect to the Y-pipe at different spots. Then you have the other two you mention (airpump and hard pipe connected to the Lower intake manifold.
hope this helps,
Dan
Old Jan 10, 2002 | 04:37 PM
slopoke's Avatar
yea i was refering to the hard pipe. what does this hose do, what purpose does it serve? just curious, i like knowing stuff, thanks, scott
Old Jan 10, 2002 | 04:48 PM
Chadwick's Avatar
Mr Sparkles
It is part of the ACV (Air Control Valve) system
Dan
Old Jan 10, 2002 | 05:03 PM
slopoke's Avatar
ok, thanks a lot, scott
24seven_dada
20
Nov 10, 2018 12:03 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
Frox
Sep 8, 2015 08:36 AM
