fuel pressure gauge
Old Jun 29, 2005 | 09:02 PM
lumberjk3's Avatar
fuel pressure gauge
does anybody know who makes the gauge that paul yaw recommends?
Old Jun 29, 2005 | 10:52 PM
SS124A's Avatar
0000-09-0233
Wika
Old Jun 30, 2005 | 01:09 AM
SilverArrow's Avatar
Not to hijack, but which line do you put the fuel pressure gauge in? The return or supply? also, which one is which? 85 gsl-se.
thanks in advance.
Old Jun 30, 2005 | 01:14 AM
txredneckmedic's Avatar
should be the supply line i believe
Old Jun 30, 2005 | 01:17 AM
TurboSE's Avatar
hmmm I would say the FEED line since the return is after the FPR
I'm not sure B/c I have an aftermarker fpr/and gauge and i got rid of the stock regulator.........and the feed line is the one closer to the engine(the inside one)
Firewall
Old Jun 30, 2005 | 01:18 AM
TurboSE's Avatar
NVM i'm pretty sure it would go in the supply(feed) line
Old Jun 30, 2005 | 08:35 AM
SS124A's Avatar
0000-09-0233
if you need a good fuel pressure gauge,
either buy the one from Yaw... (it costs just as much if you buy it from an industrial parts supplier....)
OR
Inglese has a real nice 0-10PSI glycerin filled gauge for around $20.
If you call, Ask for Dan.
Old Jun 30, 2005 | 11:51 AM
frigidmonkey's Avatar
rotor withdrawal
inglese?
Old Jun 30, 2005 | 12:32 PM
sctty's Avatar
http://www.mcmaster.com/
part number 4026K2, 0-5 psi
Old Jun 30, 2005 | 07:03 PM
lumberjk3's Avatar
thanks for the info guys. looks like you can buy the wika gauge direct from the company for about $21.58 I think I'm going to go that route.
Old Jun 30, 2005 | 09:45 PM
wouldn't i need a gauge to go higher than that with the gsl-se anyway? or is it a low pressure system?
Old Jun 30, 2005 | 09:50 PM
TurboSE's Avatar
yeah i think the other guys think u hhave a carb
Get the one that reads 0-100 PSI
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
