Microtech Series 5 turbo II motor in 1st gen...fusible link questions
Old Jun 3, 2005 | 11:57 PM
fcdorifto08's Avatar
I just wanted to see if anybody has put a turbo motor in a 1st gen running a Microtech. One issue is the center fusible link keeps smoking/breaking. I reconfigured the wiring so the power supply for the coils is no longer coming from the
stand alone, i was thinking that the coils were maybe too much, but the same problem still persists. Any info/insight is greatly appreciated.
Old Jun 5, 2005 | 03:29 AM
myexlex's Avatar
talk to luim7 he is using microtech on fb. The power supply for the coils isnt supposed to come from the microtech. Only the signal wire hooks up to the coils. You should see 12v to the coils when key is in on possition
Old Jun 5, 2005 | 07:30 AM
puntorotary's Avatar
Rotary Mechanic
which microtech are you using? And myexlex is right,your not supposed to use power from the microtech.For the LT10 the 4 cables.. the yellow,yellow/black,orange,orange/black,those are the ones that go to the coils and those are negatives,the positives come from the battery thru a relay then to the coils.
Old Jun 5, 2005 | 12:00 PM
myexlex's Avatar
the wires you mentioned are for the injectors. The ignition should be 3 grey cables, Ie. grey/red,grey/blue.
Old Jun 5, 2005 | 01:39 PM
Rotary Mechanic
negative ghost rider...for the LT10 with the x4 box its the ones i stated above.
Old Jun 9, 2005 | 02:13 PM
Thanks guys.
cristoDathird
28
May 30, 2019 08:47 PM
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
Marty RE
Aug 13, 2015 11:19 AM
