HELP!!! 3rd & 4th gear 6500 rpm hesitation??
Old Jan 1, 2002 | 08:45 AM
kwikrx7's Avatar
Do you have a Power FC? My car did the same exact thing at 6.5K in 3rd and 4th gear and it felt like a fuel-cut but from talking to Dave at KDR he says it's actually detonation and the Power FCs come with timing maps that are too high. Quick fix with programming but if you don't have a PFC then maybe it is you fuel cutting out.
Old Jan 1, 2002 | 05:02 PM
RTS3GEN's Avatar
The Man
Exclamation Plugs?
When you replaced the plugs with the 9's and 7's were they brand new ones and were they platinums or just the Q steels? If you tried to use the steel plugs you may be getting some pinging or detonation from the heat generated by the hotter range 7's. You may consider going to a set of BUR9EQP's all around, the cooler heat range helps ward off detonation because it doesn't absorb heat as well and maintains a good spark. They will foul a little faster but it's worth it. You may even try installing a set of Race plugs. If the problem still exists then you may check elsewhere, ie fuel filter, fuel delivery system. The race plugs are virtually gapless and will ignite very well. If the hesitation goes away, you may consider getting an ignition amp or check to see that the lead coil isn't going out... Just give it a shot, you may get somewhere.
art
Old Jan 2, 2002 | 01:18 PM
Bacon's Avatar
IRS 4 Life
i know ive seen this posted just recently, and dis1 replied and hit it on the nose your hitting the fuel cut...your running 13psi on a stock ecu. ARE U NUTS!!!!!!! its not happy with that..so it cuts fuel so u cant mess it upo any more..turn boost down to 10psi and see if it still continues...
or buy a ecu and dont worry abt lowering the psi..
bottom line the more u do it the more likley your gonna pop the motor..turn the boost down
yup here it is
https://www.rx7club.com/vforums/show...threadid=42134
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
REX7&Z32TT
Sep 9, 2015 05:16 AM
