Can somone help me make a oil feed line?
Old Apr 12, 2005 | 07:46 PM
spoolin1012's Avatar
All right, I want to make an oil feed line for a t4 turbo. What i know so far is a i need an adapter for the turbo feed/return. Were i am confused is what fittings do i need for the engine to the turbo and from the turbo to the engine. What size hose? What size fittings? What thing everything? Maybe this will help some people cause i did a search and found nothing. Thanks.
Old Apr 12, 2005 | 08:00 PM
2a+RoN's Avatar
you could either run -3 or -4 an line for the feed. You will need an adapter to either go on the front iron housing where there is normally a banjo bolt, or put the adapter on that hard line coming from that place. I forget the exact specs of the adapter, i think it it 14x1.5mm to -4 but I'm not certain. Then you would need an adapter to go from the -4 line to your turbo oil inlet. I just bought a set of 5 three foot -4 lines with the hose ends, so if you want one, let me know. For the oil return, you would want to use probably no smaller than -10, but -12 would probably be preferred. Also, remember the return out of the turbo must come as close to vertical as possible as it drains using gravity.
Old Apr 12, 2005 | 08:10 PM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
Seek (or search) and yea shall find...
https://www.rx7club.com/single-turbo-rx-7s-23/perfect-oil-fitting-adapter-13b-rew-389236/
Old Apr 12, 2005 | 08:19 PM
EKTwin93's Avatar
If you're planning on using the stock hard line that runs across the block to near the turbo, you'll need a 14mm x 1.5 adapter --> whatever size line you want to use. I used -6 AN line , so I bought a 14mm x 1.5 (male) --> -6 AN (male). The fittings on the line ends are female, so that will hook right up to the line. Then, you've got to go from a female -6 AN line end to your turbo. My T4 had a 1/4" female feed already tapped into the center section. So I realized that the female -6 AN fits perfectly onto a male 1/4", so all I had to do was buy a 90 degree fitting with male 1/4" ends on each side, and screw it all together. The fit from that stock hard line to a turbo is really tight. I had to buy 3 ft of line...I used ~3 inches.
For the turbo drain, I got a T4 turbo drain flange with a 1/2" female tap. I used -12 AN line. So, I had to buy a fitting that was 1/2"(male) --> -12 AN (male). That will go into the female fitting on the end of the -12 AN line and you're set. I just cut my stock primary turbo oil return hard line and double hose clamped the -12 AN line to it. The return line isn't under pressure and this way you won't have to fabricate some flange to bolt up to the stock return. So that may seem a little confusing in paragraph form. Here's a list of what I used,
Feed:
1 14mm x 1.5(male) to -6 AN(male)
1 -6 AN SS braided line
2 -6 AN (female) line end fittings
2 male-male 1/4" threads
1 female 90 degree 1/4"
Return:
1 T4 Turbo flange 1/2" female tap
1 1/2" (male) to -12 AN (male)
1 -12 AN line end fitting (female)
1 -12 AN braided SS line
I ordered everything from Aeroquip/Earls Performance Products throught O'reilly auto parts. I took about 2 days to arrive and cost about $130 If you got any other questions or need something clarified more just shoot.
-Evan
Old Apr 12, 2005 | 08:50 PM
TT_Rex_7's Avatar
How about water lines?
-Alex
Old Apr 13, 2005 | 01:05 AM
13BNUT's Avatar
Feed:
Return:
-Evan
http://bdc.genxracing.com/BuildingTu...s_FC3SFD3S.txt
On this write up it does say what size adapter to use for oil feed line
(metric size/pitch) unknown
Is it the same as FC
Old Apr 13, 2005 | 01:06 AM
13BNUT's Avatar
Can I still use M12-1.5mm to -4AN
or M14-1.5mm to -6AN??
Old Apr 13, 2005 | 09:40 AM
BDC's Avatar
BDC
BDC Motorsports
For the FD block it's an M14. The FD and Cosmo blocks have a slightly larger tapped hole there on the front iron housing.
B
Old Apr 13, 2005 | 07:19 PM
EKTwin93's Avatar
They make just about any adapter you'd need. If the FC has an M12 stock fitting, then yes you could get M12 (male) --> -4 AN (male). You can go with whatever line size you want, I just went with -6 AN out of personal preference
Old Apr 13, 2005 | 08:37 PM
13BNUT's Avatar
Thanks alot
This is an awesome thread
lots of useful information for us newbie's with single turbo
Old Apr 13, 2005 | 09:30 PM
just to let you know i went through hell to find that fitting!! but i ordered like 5 of them and you can buy one from me if you want... also, i can sell you that and make you a -4 ss line with the fitting... LMK...
Thanks!
Old Apr 14, 2005 | 12:10 AM
2a+RoN's Avatar
ooh, i need the fitting if it's the 14x1.5 for an FD...
Old Apr 14, 2005 | 03:22 AM
i have the fitting and the line together... LMK if you want it!
Thanks!
btw, good luck trying to find the fitting!! its on backorder for 1-2 months or something like that!
Old Apr 14, 2005 | 09:32 AM
2a+RoN's Avatar
How much for the fitting by itself as well as price for both together?
Old Apr 14, 2005 | 03:14 PM
Bacon's Avatar
IRS 4 Life
https://www.rx7club.com/single-turbo-rx-7s-23/oil-line-banjo-bolt-122033/
Turbostreetfighter: Builds parts for NASA and I have used the same thread without a problem but my max oil psi has been 20 psi since I haven’t fully started my engine yet, but a little gas safe Teflon tape and your set.
"the TPI ( thread per inch) is the same on the FD block as a 1/4-NPT fitting!! if you use a 1/4-NPT to -4 male JIC straight fitting and gasoline application pipe tape it will not leak and then you can run a custom line to feed your turbo with no fear of leaking!!"
Old Apr 14, 2005 | 05:11 PM
$50 .... thats a foot and a half of ss line and the fitting... kg parts sells the same line for $56 + shipping.. and you cant get a hold of that guy! i waited 3 weeks for an answer from him and i finally made them myself! but let me check if i have any more.
-Roman
Old Apr 14, 2005 | 07:06 PM
2a+RoN's Avatar
what about for just the fitting?
Old Apr 14, 2005 | 10:50 PM
BDC's Avatar
BDC
BDC Motorsports
Guys, use this as a reference.
http://bdc.genxracing.com/BuildingTu...D3S/index.html
B
Old Apr 15, 2005 | 03:05 AM
i get just the fitting for like $12 with tax or something.. but ill sell only the complete thing.. if not, order the fitting online.. its not worth the drive for me..
-Roman
Old Apr 15, 2005 | 05:18 AM
black93RX7's Avatar
20BFD
Does anyone know the fitting sizes to run this setup for a T78?
Will a T3/T4 Oil drain flange work on a T78?
oil feed is done, just need return sizes.
What size is the return hard pipe comon off the block?
Thanks
Old Apr 15, 2005 | 07:52 AM
rxrotary2_7's Avatar
-Roman
Actualy in your PM you showed me how the fitting itself cost $8.00 from some place. Right there I knew you had it in your head that no matter my price, you felt it was worth only $8.
Actualy the line I sell is $56 shipped and comes with the correct metric to JIC fitting for the block, the line (professionally assembled and able to hold 3000psi) and whatever other adapter you need to thread into your turbo...
I did not reply to you on purpose as you basicly stated your price, or should I say what you "felt" your price "should" be. Glad you now see the fitting needs to be stockpiled to be readily available for someone like yourself who needs it "yesterday" and overnighted to them....
Anyway, yes I do have the lines for $56 shipped assembled and ready to go 99% of the time, and yes I am sometimes a little harder to get ahold of as I am a busy man. And yes, you may wait longer than 3 weeks if you happen to proceed to tell me how much the absolute cheapest place on the internet sells a part for. By me not responding is basicaly telling you that you have already found your source if you can link me to it.
Sorry if I sound harsh, but you did just say something about me that I felt I should defend/explain. No hard feelings? good.
Old Apr 15, 2005 | 10:00 AM
2a+RoN's Avatar
I read this and just thought you had extra fittings, otherwise I wouldn't have asked about it alone. Where did you order them from then, so I can just order one myself?
Old Apr 15, 2005 | 12:45 PM
EKTwin93's Avatar
The T3/T4 oil return flange bolt spacing is 2" from bolt to bolt. The stock hard oil return line fits perfectly into a -12 AN ss braided line.
Kyo
Aug 14, 2015 02:00 PM
